- Feb 24, 2020
- Auburn, Georgia
- Zach
- Sierra 1500
^Oh! There ya go!
Yes they would; we did it all the time.I doubt GM would have spent the money to stamp a hole, then design a plug to fill it up if it had no purpose.
I did check, the adapter from the passenger side seems to fit the drivers side. So it appears they are interchangeable.
That is EXACTLY the look I’m hoping to accomplish.This is my setup on my 84 with 454.You must be registered for see images attach
My brainstorm idea is to use another stock air cleaner, carefully cut the snorkel out and weld it to my existing air cleaner and use another grill opening adapter.
IIRC my 1980 with 250ci inline 6 was driver side, PS was hacked open partially to run A/C condenser hosesI've not seen any use the driver's side, pretty sure they all used the pass side. But you could probably just rob extras of the pass side to make your own, I doubt it would be that hard other than welding the other snorkel to the lower housing (just cuz it's kinda thin metal)
Let's see the super beetleNeed to make the same set up, but for a 4bbl 4.3 that is getting reworked. Might just use the Spectre (?) stuff cobbled together. Gotta “fancy up” everything on Lisa’s lowrider tow pig, the C10 has a “pet” flat windshield Super Beetle…
Spray paint color test. Will be done in actual automotive urethane base/clear. Mopar Sublime green door cards, seat pipng and seatbelts that I rewebbed using factory hardware. ARE 8 spokes, will have Waterfall 195/55vr15 fronts, 215/70r15 rears.Let's see the super beetle
Cool little carSpray paint color test. Will be done in actual automotive urethane base/clear. Mopar Sublime green door cards, seat pipng and seatbelts that I rewebbed using factory hardware. ARE 8 spokes, will have Waterfall 195/55vr15 fronts, 215/70r15 rears.
New 1406 for the truck arrived today. Will order a 2111 intake next payday. Swiped the new manual choke Qjet for 1 of my 350 powered 4wd gmt400s…
