Engine ID
xtremek
St Johns, Mi
Kirk
c30
Got a "new" engine for my wife's 82 C30 dump truck. Timing set is worn out. Engine number is 10243880 (vortek, correct?). Cam sprocket is 340235. Year? Car it's out of? Project is weeks overdue. Mercy, please.
That's a later casting block. Cast in Mexico. Could be an L31 or could be a crate motor. Could be Vortec or not.
You need to get the cylinder head casting number and the stamped number on the pad in front of the passenger side cylinder head. What intake is on it? Does it have a roller cam in it? Mechanical fuel pump provisions?
Pics of everything would help in identifying all of this.
xtremek
St Johns, Mi
Kirk
c30
TBI intake, fuel pump provision, pics tomorrow.
xtremek
St Johns, Mi
Kirk
c30
Cylinder head number 14102193. Stamped number is V1005PHA. Didn't pull the cam. Will it have the fuel pump eccentric?
Kurnacopia
Tucson, AZ
Scottsdale
I have that very block for my 383. here is the info I have:
10243880​
Manufacturer: Chevrolet
Category: Engine Blocks
Type: Small Block V8
Date: 1995-1999
Notes: 350, 4 bolt, crate engines and ZZ4, roller cam, one piece rear seal
Electric gas pump only
It's either a L31 Vortec or a ZZ4 crate motor with roller cam
xXmutantXx
