Dually help/opinion
Roughneck714
Vacaville
6.2 Diesel
Hey everynody! Havent neen on hell i think since my intro way back when. But i wanted to get input on what i should do rearend wise. After years of my 1984 Chevy k30 sitting Im finally started working on it. Was thinking about duallying it. Can i just convert my 14ff or go with a Dana 70?
Sent from my SAMSUNG-SM-G891A using Tapatalk
CSFJ
Iirc, there were different widths on the axle tubes for the dually axles. The d70 would probably be the cleanest route to take.
ajd89
Central Michigan
andrew
That's what I thought too
You can bolt duals right on your axle, but if you want to run a stock bed with dually fenders, you will need the D70. It has a wider housing.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Cab and Chassis rear and spring mounts and keep the normal bed
CSFJ
According to the old pontiac commercials, wider is better.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Are we to believe an anorexic coyote? He’d say anything to get a meal. Lol
CSFJ
The spring hangers wouldn't be needed, all the 1-ton rears use the same narrow spring spacing.
ajd89
Central Michigan
andrew
This is what it would look like with duals on your current rear end.
Idk that's pretty bad ass! That' not a cab and chassis rear end?
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
I read the post related to the picture and it is a cab/chassic rear end, but it would give him a close idea. My K30 has the 2000+ alloy wheels. You can see from the photo, I could fit a dually wheel with no issues.
Roughneck714
Vacaville
6.2 Diesel
That rig looks sweet. But I really want that wider ass end look. So the Dana 70 is what Im thinking is the route I need to take
CSFJ
That is so badass!!!!
Kinda surprised yours isn't set up like that by now. They don't get pissy about an extra set of swampers digging on the back in your class?
alwaysbroken
