Drive shaft rubbing "Y" pipe
brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
So I just bought this 86 Custom Deluxe. Had to have it towed to my house and fix some things the PO was working on to get it running. Still have some tuning to do but it runs. I noticed the front drive shaft appears to be rubbing on the "Y" pipe of the exhaust. It has a practically brand new Rough Country 4" lift on it. Still has stickers on the springs. Anyone else had this kind of issue? What did you do to correct it?
SquareRoot
Yep. When I bought my k20 I wondered why the front shaft was sitting on the floorboard. Cut the exhaust out, and reinstall correctly with the shaft installed. Need about 2 inches clearance at ride height.
brooksman9
Olive Branch, MS
Patrick
350 & 305
Ok. At work so cant get any pics right now. It is touching at ride height so I will cut it and distance by 2" minimum. Couple of couplings should do the trick. I'll post some pics when I get a chance. Thanks.
brooksman9
Olive Branch, MS
Patrick
350 & 305
Got a pic. This is what I'm looking at now. Thought about cutting the down pipes and extending but they are angled a little different on each side. I may still be able to do it. Have to look a little closer when I have more time. Probably wouldn't be so bad if it only had a 2" lift which is what I'd really like to have.
Camar068
Kentucky
10 yrs Air Force
if you can afford it, just go dual
brooksman9
Olive Branch, MS
Patrick
350 & 305
That is a possible solution. I just bought a set of headers for the other truck that is not going to run for a while as I just started tearing it apart for restoration. I'd like to see if I can come up with an alternative solution first though.
RanchWelder
Earth
Blazer
350ci
Cut it out... (No really... cut it out...).
The Y-Pipe is the worst design exhaust ever. It scavanges very poorly.
The restriction on the passenger side head flow is enormous.
Somebody got creative with the pipe added going down the passenger side, cut into the Y-Pipe.
So you don't neet to connect them, if you don't want to.
(It is not even close to an X-Pipe, the way it is now anyways).
Craig85's solution is good enough for a pickup, because the equalizer is reasonably short, however on the 4WD it will be a PIA.
You ever need to drop your transmission, somewhere down the line, you'll be glad the stoopid Y-Pipe is out the way.
Add 2 new modern Cats, weld up the holes and call it good for another 100,000 miles or replace the entire mess with a 2-1/5" system with turbo's like Craig's.
Ya'll Git'on Outt-ah hee-ya!
:893Chainsaw-Smilie-:superhack:
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
Craig
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
I like the sound of true dual pipes, easy to work in stuff underneath, mine exit in front of the rear tires. When I smokem, it makes a huge cloud. Also great if you actually use your truck as a well, truck.
SquareRoot
I'll take a well engineered y-pipe over duals any day. My hooker exhaust manifolds and 2-1/2 inch y-pipe clear everything with room to spare. Doesn't interfere with trans removal either. Into a 3 inch pipe, high flow cat, magnaflo muffler and single exit. Clean, simple , effective. Does nobody watch Engine Masters? The Dyno proves you don't need big azz tubing and all that crazy junk. The single 3 makes more hp than duals almost every time. No h or x pipe. Be realistic about how the engine operates. I rarely top 4 k.
brooksman9
Olive Branch, MS
Patrick
350 & 305
What kind of manifolds are those?
Hard
