Draining Torque Convertor
davbell22602
Bunker Hill, WV
I Dont
Have
One
Anybody got any ideas on draining trany fluid from a torque convertor without the machine.
Swims350
Logan WV
none
take it out and then turn it upside down and drain it.
If not drill a small hole in the bottom, then find a plugs to fit that hole later. I got a TC somewhere that has that done to it.
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
Just flip it over
It'll take a while to drain it all out
davbell22602
Bunker Hill, WV
I Dont
Have
One
My pan gasket is showing early signs of leaking and I wanna switch to synthetic trany fluid. But no major leaks yet.
davbell22602
Bunker Hill, WV
I Dont
Have
One
I figured out how to drain the torque convertor without removing the trany or using the special pump/machine.
Here's what you gotta do. Remove the return line from the cooler on the radiator and place it over a bucket. Then start the truck up and let it idle. Then when you start seeing air bubbles or foaming then its done emptying the trany fluid from trany. May need 2 more after it cycles through a couple of times.
Swims350
Logan WV
none
sure if you want to risk it.
I'm too afraid to run my motor with trans empty.
Centrifugal force keeps the fluid in the converter don't it? I am afraid to touch my trans oil, I hear a lot of bad things happening if it's been in there a while and you put new fluid in it fuggs it up.
davbell22602
Bunker Hill, WV
I Dont
Have
One
You dont run it dry. Say your doing a filter change and pan refill and all you need is 5 quarts to refill the pan. Then you mark a bucket at 4 quarts. Then when it reaches that 4 quarts STOP THE ENGINE and refill trany. Repeat til you done a couple more quarts than a pan refill.
Well, let us know how it goes....
towman
harrisburg pa
jay
v10
that is called a red neck transmission flush, he will need a trans before it is all over
davbell22602
Bunker Hill, WV
I Dont
Have
One
Forgot to add also that to add your replacement fluids as it disposes the old in a bucket and keep the funnel full until you reach the mark on the bucket. This this for a complete fluid change or flush.
78ALB
