- Jul 3, 2012
- Right where I am
- Bagoomba
- 81-C20 Silverado Camper Special-TH400-4.10s
- Carb'ed Vortec 350
Got the brakes done, well almost. Got to drive it, and it stops a whole lot better, and that's without doing the rears. The rears will get done soon. The front end is aligned, and the truck rides nicer with the newer springs on the front. Was going up to Mom and Pop's on Saturday and the left front developed a bad knocking sound. I suspect the crappy China-made pads are to blame. The sound goes away when the brakes are applied. It sounds like a stampmill at low speeds. Limped the truck home, and yesterday I found other things to do than work on the truck. I'm sure there is damage from the sounds it was making. Reluctant to look, but I will get to it this week. I am hoping the damage is minimal. Have replaced brakes before and have never had the pads make such noise as this one is doing. I am really disappointed in the Classic Performance Products 3/4 ton disc brake conversion kit. The ball joints they provided couldn't be used, the castle nuts was loose on the studs, the tie-rods were crappy, the spindle diameter was wrong and needed to be shaved down to allow the bearings to slide on, the rubber brake hoses were wrong, basically I only used 5-10% of the whole kit. What a waste of money. Had I known what I really needed, I would have just sourced the parts from a junkyard. Lesson learned.
