Detroit Speed Engineering versus UMI front coils.
shawn57nomad
Supporting Member Navy
Midwest
Just an FYI-
Both companies have great products! The DSE front coils had the tires way up in the wheel well (probably a 3" drop) and I thought I'd try a set of UMI 2" drop springs. The rake was significant and I was definitely in the weeds with the DSE's. My 81 SWB does also have CPP UCA/LCA/2" Drop spindles.
Opposing side shots for reference on level stands.
shawn57nomad
Midwest
Detroit Speed springs 950# pt#031141-950 0622
shawn57nomad
Midwest
UMI 2" springs
shawn57nomad
Midwest
Detroit Speed on left, UMI on right
ChuckN
Bellinham, WA
Chad
What was the drive feel like? Did one feel significantly softer than the other?
FWIW, a lot of guys like myself run a 60 series front tire and the DSE wouldn’t have as much tuck.
Here’s my CPP front 2.5” spring and 2.5” drop spindle on 255/60/15.
xm20k
Girard, Ohio
Mine had 2" springs and spindles and a rear flip it sat to low with the 2" springs. I couldn't get a jack under it with a flat.
This is with stock springs and drop spindles.
This is mine with a 26" tire up front and a 28" in the rear with just Wilwood spindles and a rear flip as far as drop. a 28" tire would take up some of the gap and give it less of that "race car" look.
shawn57nomad
Midwest
I believe the DSE springs are near a 3" drop. UMI 2" just installed it's right near level and ever so slight rake. The Detroit springs though I was in the weeds. Loads of tuck on a 7" wide wheel.
shawn57nomad
Midwest
The ride was good either way running the KYB Excel G shocks per the information here. I think the spring rating is near the same between the 2 companies. I did lop off half of the CPP LCA bump stop due to the Detroit springs having about 3/4" of clearance to the top hat for the spring before contact. Handles really good now with the front 1-1/4" CPP sway bar though.
TXK5BLAZER
