Dents, and rust help
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
So the 87 cab I got the other day has some dents and rust. The main dents I've seen are on the backside of the cab where the bed meets it. Guessing something slid up and hit cab not sure. Heres pics of everything
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
more pics
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
Honestly my 85 cab is in better shape imo it would require a lot less body work than this cab it only needs cab corners and rockers and the dash in the 85 cab isn't cut. Any suggestions would be great.
Moderator Administrator
For the rust you could use your other cab to create patch panels for this new can with the good vin. You could also do the same for that dented portion on the back of the cab but someone with more bodywork experience will chime in hopefully.
87lsxgmc
buffalo
i think you can find a better core to start with, but if the price was right you have the time to straighten it out, its possible. do you have a good mig welder?
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
I'm thinking about just swapping out dashes since the 85 cab is in much better shape than this cab. The only reason I bought this cab and went to the hellacious trouble of pulling it off and bringing it home was the fact it had a good vin # with matching title. The 85 cab only needs some rust repair in the rockers and cab corners but I could use metal off this cab for it. Seems like it would be less of a headache and a lot less time.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I have scrapped far better cabs than that 87 cab
swap the vin or the whole dash
don't waste your time fixing that cab
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
that's what I figured would be best to do it would take a lot less time
Moderator
I'd swap the dash, I think that's technically legal as far as the title goes.
MadOgre
NA
NA
NA
NA
NA
x2.
MadOgre
NA
NA
NA
NA
NA
just replacing parts...... like everything lol
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
I think the dash swap is going to be the best thing less time consuming as well
Rangelloz
