- Oct 27, 2016
- MO
- Spencer
- 1971, 1̶9̶7̶4, 1976, 1979,1̶9̶8̶5, 2002
- Dart Swinger, Sierra 10, C10 Cheyenne, C10 Big Ten, Silverado 10, Ram 2500
- 225/6, 350 c.i., 350 c.i., 5.9l Cummins
What is the rag trick?
I just use a pry bar in the carrier in the open area where the spider gears lie or a against a ring gear bolt and turn the pinion and it will walk out.
The carrier being hard to remove is a good thing, that means the bearings have good preload. Dana specs a maximum of .015 spread on the case for carrier preload (IIRC). If it was that tight a case spreader should have been used and it would slide right in and out.
