Cutting Sheet Metal
How do you cut a long piece of sheet metal in a very straight line? Can it be scored and snapped somehow? Or put in a home made jig?
I have regular cutting shears, just wondering if there was another way, or home brewed trick.
I need to cut those wheel arch panels. They are about 3 feet long, and I want to remove about 4 or 5 inches of the top of them. And I hate having a ****** looking edge.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
I clamp a piece of 3/4" thick sheeting board to the metal and use it as a straight edge for my 4" angle grinder with a metal cutting wheel. Works better than a jigsaw or sawzall. When I was doing aluminum fascia for houses we would use a 10 or 12' metal brake, clamp it down on your marks and score it with a razor knife several times, then work the brake lever, bend the metal back and forth several times till it breaks. That was with aluminum though, not sure how well that would work with steel. If you had access to a metal shear would be the best way but it just all depends on how long of a cut you need to make. If you're cutting on your new body panels and they're kind of long, clamping the board on and using the angle grinder might be the best/simplest/fastest way.
So make a guide basically to clamp onto the metal, I got ya. I'll have to pick some cut off wheels up for the grinder.
davbell22602
Bunker Hill, WV
I Dont
Have
One
Can ya borrow a cutting torch for the straight cuts and plasma cutter for the curved cuts? Saw saw might work too.
C4 took the words off my keyboard :waytogo:
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
I need to cut those wheel arch panels. They are about 3 feet long, and I want to remove about 4 or 5 inches of the top of them. And I hate having a ****** looking edge. QUOTE]
Dave might wanna go re read the part in RED
davbell22602
Bunker Hill, WV
I Dont
Have
One
Read it. He can use grinding stone on drill to clean up those edges.
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
How about a pocket knife? :shrug:
I don;t use air tools. Anybody ever thro a metal cutting blade on a table saw?
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
I thought about something similar, metal cutting blade on a skil saw. Probably work just fine.
Would that be taking my life in my hands using a table saw, lol!!!???
How sharp are your teeth?? :D
