Custom exhaust size?
FranticMeeping
Minnesota
6.2 Diesel
Needing to redo the exhaust on 6.2, guy in neighboring town bends custom exhausts. Just curious y’all’s opinions on what size to go with? I believe it is 2 1/4” now. My old 78 K10 with a 350 had a nice sound with 3” and Red glass packs. Is that overkill for the noise police anymore? I did that 20 years ago when I was 19,
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Are you talking dual 2-1/4 or single?
Either way, don’t waste your money on mandrel bends. I makes no difference in performance.
Camar068
Kentucky
10 yrs Air Force
there are exhaust calculators out there
Magna86
VA Beach
Magna86
Chevy 350
2.5" nothing more and a good set of mufflers with pipes to exit the rear. Helps eliminate drone and getting black exhaust soot on the truck.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
On my pickup, the factory build was dual pipes, 2.5" from the manifolds to the muffler, from there the tailpipe was 2.25". I can't picture any benefit to putting anything bigger than 2.5" on it.
Its a diesel, you aren't going to have any real benefit or awesome sound from a big dual exhaust. I'd probably just go with the cheapest decent exhaust, which means it would just be 2-1/4" dual exhaust with cheap turbo mufflers.
SquareRoot
Stacks!
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Right. Also consider that bigger pipes on an engine that doesn't turn that fast slows the exhaust velocity, and with a diesel it pays to project the soot as far as possible.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
Craig
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
1 7/8 headers to 3" pipes into Holley Aero chamber mufflers in front of the back tires, blowes the tire smoke most excellently sideways. I love the sound of the foe fiddy foe, also the reason I won't drive an electric vehicle.
Raider L
Shreveport, LA
William
Headers, the only way to go. 1 5/8" primaries into a 2 1/2" collector, 2 1/2" duals with Flowmaster mufflers as close to the rear end as is practical, exhaust pipes over the rear end, exit either straight out the back, or "highway style" turning out just after the rear tires. That's the way I have mine. This is for small blocks. Diesel, I have no idea. Would it be the same as a big block? Otherwise 2" primaries, to a 3", maybe 3 1/2" collector and the same parts, i.e. mufflers, tail pipes. Is that the way ya'll do it?
82SquareBurb
