cold radiator?
Dave M
Banned
Australia
Dave
Hey, how do you put a photo in the block above my name? I have a photo of my truck I can put in there.
Click on your Profile, then click on the square on far left which is your Avatar l think. Best of luck with me giving computer advice.
Raider L
Shreveport, LA
William
Here's some pics of that cold ass radiator I put in this Spring. And some additional photos of my vacuum canister that I put in when I had my big cam in that only had about 5 in. Hz and 9 at idle. I had it plumbed into a vacuum pump so I could disconnect the vacuum from the engine and run the power brakes off the vacuum pump and the cannister. And a little vapor canister that I got out of a Mazda RX7. Not a very good photo of it. I'll take a better one tomorrow. I wanted to get rid of that giant ass factory canister even though I wasn't going to plumb any EPA crap in on MY engine. I did want a little something just in case some enterprising inspector wanted to catch me at violating the law for not having a vapor canister. Yeah, I do have one even though it isn't hooked to anything but the gas tank. And just not knowing what I was looking for, I just happen to look in this little RX7. And right there on top, right in the open was this cute little can. I thought,
perfect!
Raider L
Shreveport, LA
William
I messed up the pics. I think I clicked something I wasn't supposed to click.
you need an air deflector up top and a fan shroud if you are trying to cool anything. the deflector is also the mounting plate
Raider L
Shreveport, LA
William
AuroraGirl,
Yeah, and I've got a good one I made up so it's not such a hassle to get to the front of the engine like to remove a fan or whatever.
You take the shroud and cut it in half. The you get a piece of 1/2" alum. angle and cut angle cuts in one side so you can shape it around the shroud. Pop rivet the side up against the shroud.
Then do the same on the other half of the shroud. Then fit the two ends together and clamp them together. Drill holes in the sides of the angle that are together. Then turn screws of your choice into both holes that are still clamped together so that the holes line up.
Do the same thing to the other side of the shroud and now you have two halves you can remove anytime you need to.
This shroud caused me a pain for a long time. I don't know why I thought I had to deal with it in one piece. Then one day I thought why do I have to keep it together. I'll cut this sucker apart and fit it back together and I can take it apart any time I need to. Necessity is the mother of invention.
You leave the bottom half in the clips at the bottom of the radiator support. Then when you are through, put the top back in, without removing anything, puill the sides together and start s couple of screws and then you might put a couple of those bolts in the top piece that are fixed to the radiator support to hold the top shroud, and put the rest of the screws in, then the bolts, and you are done
millernf
