- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
Couple of tests:
-It should be pretty stiff to turn when cold (cold=engine hasn't been run yet).
-It should roar for about the first 5-10min after cold start up in the morning, and then go silent. If it doesn't do that, it's dead.
-If you see oil w/ dirt stains on the face around or behind that temp sensing spring, or out of the backside where the shafter enters, it's either dead, or soon will be.
-They don't engage until 230*F so it takes a lot of heat to get one to hook up. But once they do, it actually sounds like the transmission has down shifted because suddenly the engine just roars like a freight train. It's very noticeable inside.
And yes, they are sensing air temp coming through the radiator.
Well, according to that list I can tell you mine must be shot. It only does that cold start roar very rarely. Like once every month or 2. Another part to buy.
