Vbb199
B-rate Hillbilly Customs
- Jan 12, 2018
- Salisbury NC
- Vince
- 89 Suburban R1500, 79 C10, 99 Silverado
The motor is covered right now.
Throwing it out there for anyone interested. Its listed on marketplace also. The big block 502 from my c10 with holley efi with long tube headers. Ive got timing control integrated also because I locked out the HEI and installed a holley module in. There was also push button traction control wired in thru the system also.
Motor has less than 1000 miles probably. You're welcome to check compression, bore scope the cylinders, I dont care.
I have the motor listed with the holley and headers for 8 grand on Facebook marketplace.
The th400 is still attached to it, and youre serious about it, we can fire it up. The fuel tank, lines, radiator, and electrical stuff is still all rigged up.
For some more cash, you can just take the whole damn thing. Frame, trans, motor, driveline.
The rear end is a truck 12b with a Detroit tru trac, crush sleeve eliminator and yukon 3.73 gears. All new brake hardware. 1350 yoke, 1350 driveshaft, 1350 trans output.
Th400 trans, with a small laundry list of build mods. 2400ish stall.
