C10 stock front suspension travel (1985 sbc)
Logbed
Europe
Caleb
C10 Silverado Longbed
Have you measured it without the spring and swaybar? It would help estimating where a bigger tire might touch when at the bottom of the travel. (The rear is interesting too but with the solid axle and leafs it is almost impossible to measure all the possibilities of the rear wheel position and angle.) I'm running 32x11.5R15 tires on the stock 8" wheels with front liftted 1,5" and there seems to be plenty of space. Planning on 33's with 9 to 9.5" wheels...
It's gonna hit the bottoms of the fenders front and rear and also the bottoms of the inner fenders. More offset just makes it worse. Seen plenty of these things cut to clearance for tires, it's not a good look IMO
Logbed
Europe
Caleb
I taped 1,5 inches wide piece of cardboard vertically inside the fender and hit some speed bumps. Did not touch with my 32" tires so it seems there will be enough space for 33"s too. Propably my 1,5" front lift helps as it stiffens the suspension too.
Geoduck
PNW
Logbed, I'm curious how you were able to lift the front of your 1985 C10.
I would like to lift the front end of my 1985 C10 about one inch to clear 30-31 inch tires on five lug 15 inch wheels.
legopnuematic
Licensed Junk Dealer
MO
Spencer
31’s should clear fine if the truck has stock springs up front.
I run 31x10.5x15 K02’s on my 76, stock wore out front springs, 15x8 steel wheels with 4” back spacing. No issues.
fb_img_1753500988114-jpg.402523
Geoduck
PNW
Thank you for the detailed answer Spencer. Exactly what I wanted to know!
Great looking truck!
If you need to end up raising it,coil spring spacers are cheap and easy depending on who you believe 3/8th will get you an inch,others say 1/2"will get you an inch
Logbed
Europe
Caleb
I installed the lowest sub 1" lift but it ended up lifting a lot more. +1.5 inches. You'll end up removing lower ball joints so get them new too.
jw23655
