Brake caliper
bigge31566
GA
Ervin
I want to change the brake calipers on my 83 C10 and go with more performance caliper or front braking, but cannot afford to go the wildwood way too expensive, any other ideas that will work, just want something a little stronger for 450 hp engine
gpmorgan
Tupelo Ms.
greg
Do you have big wheels on the truck? Might check the rear brakes and make sure they are in good working order. Might even try a disc conversion on the rear. I didn't find many choises for front brake upgrades other than pads.
bigge31566
GA
Ervin
I will be putting 20 in wheel s on and I put new pads a drum disc on but I could change to disc if it isn't too expensive. Any ideas
circuitguy
Elk Grove, CA
BIG-C
GMC 1/2 ton Stepside
Check out CPP online,
http://www.classicperform.com
They have many options for brake upgrades and there prices are not that bad. Here is my front brakes from CPP, go check them out...
79K10
Sacramento,ca
Ryan
350/th350
i know this is an older thread but i cant get the front caliper back on... is there some trick that i need to know? i dont remember my 79k10 being this big of a pita, its the same part number pads for both trucks... tia
79K10
Sacramento,ca
Ryan
350/th350
ok, figured it out, it was something small... those two little sleeves that the allen bolts go through were sticking out and stopping me from pushing the caliper in... pushed those out the way and it slid right it, then i used some needle nose pliers to pull the inside pad back up so i could slide the bolts in (they hold the inside pad up at the top by the tab.
so this tab
and this one needed to be pushed back towards the motor
ah now i feel better... but after checking out the rest of the brake section, i want new rotors and calipers. lol
time for a beer
yes, the shock is broken off the top mount... thats tomorrows project
dan86
