Subourbon
- Apr 28, 2020
- Quebec
- Eric
- K20 suburban
- 6.2 V8
Hey folks, 82 suburban 6.2 diesel 700r4 4x4.
My rear brake reservoir was pretty much empty. Pedal had nothing then very very hard pedal about 1/3 of the way down.
And brake light was on.
Yay
So, I bought 2 wheel cylinder preemptively, and the proportioning valve centering tool, so that I can bleed without sliding the shuttle valve inside.
I think mines original to the vehicle coz it looks like it has seen some sh*t. The lines will likely just snap if I try removing them to work on the valve in a bench.
It's a 5/8 socket or wrench thats needed. And it will not budge. It's in that really accessible spot under the rad support. And i dont really have room to swing a ratchet
It feels like I'm slipping off of it, but a 15mm or 16mm won't go on either.
I'm here venting coz there's not much room in there and I'm pissed off. Also coz I'm wet coz it snowed today. Too early for this crap
I sprayed some jiga lube on it. I'll try in the morning I guess.
I absolutely need that centering tool to bleed the rear right?
Asking coz, what if I crack a bleeder on a front disc (either one) and stomp on the brakes a bit, which will then slide the valve over to the middle.
And then, gravity bleed the rear. As I (once I fix my leak of course) open A bleeder on the drum wheel cylinder and keep master cylinder topped up and let it bleed though bleeder screw by gravity, and tighten it up when there's a steady trickle of brake fluid.
Does that work? Or is there still air in the lines?
For a sensor, that sensor is really really stuck on there. What a pain.
Sorry for the rant, and appreciate any ideas or feedback.
And yes, I plan on redoing all the brakes lines at a certain point, and replacing & RELOCATING that goddamn valve is in the plans too
Yay
