Big Block Hood Fitment
74 Shortbed
Shoulda got a Scat..
74 Shortbed
I went through 3 scat cranks be for I gave up
What was wrong with them???, haven't seen a bad one yet machining was always dead on, Eagle machining is dog **** though.
Craig 85
Nashville, TN
454/TH-400/NP205
Here's a stock '85 big block. The air cleaner base is the same as a small block. The air cleaner lid is right up against the hood when closed. The issue you will run into is air cleaner fitament, depending on what intake and carb you have. You'll have to try different bases to see what clears the carb, but will give you the tallest air filter.
1973c10
Don
2 of them had bad main machining and 1 had a bent crank snout
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Here is a BB where a SB used to live. It does have a 2" body lift though.
74 Shortbed
WOW, hard to believe that came out of their facility, wonder who actually did the machining????.:hmm:
1973c10
Don
You have no idea how frustrating it was I got 2 from summit and the other from Jegs
I ended up getting a Crower crank from summit I have had good luck with Ohio Crankshaft
74 Shortbed
Oh, I know exactly how that is, been down that road before and it sucks, lol, Crower stuff has always been good and the customer service is tops, at least they used to be back in the day, but it's been quite a while since I been in there and I know things have changed some. Ohio Crankshaft always been top of the line too..
Zoomalot
Banned
Parksville
Randy
Silverado Shorty
350 Ram Jet
Holy Dyno !!
If you need a TEST PILOT when he is done don't hesitate to contact. I like breaking them in and I won't charge a thing !!
NICE BUILD
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
You will need to upgrade your diffs...
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
And transmission...
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
And U joints/driveshafts...
MADDOG54
