Big block guys, help me out here
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Factory cab mounts. Cabs never been off. Never felt the need to change them, since they look fine.
There's something very appealing about that truck. Can't quite put my finger on it, but there's something....
Wumbo
Illinois
Rob
Am I crazy to think that I might be able to pull the bellhousing and clutch with the engine?
Remove the slave cylinder, remove 4 bolts, and support the gearbox?
Am I crazy to think that I might be able to pull the bellhousing with the clutch?
I've done it that way before... just can't remember if it was in a square or something else.
Wumbo
Illinois
Rob
That might be the ticket.
Wumbo
Illinois
Rob
I'm not against modified trucks, but....sometimes there's nothing like a stone stock GM truck.
Same here. Wanted to keep it 100% stock, down to the emissions equipment.
Broke an AIR injection tube last time I pulled the engine, so ditched that whole system. And the low compression 265hp 454 is sooo underwhelming.
Decided to build a 9:1 compression 468 with 2.19/1.88 oval port heads and Lunati roller cam. I had a set of Eagle H beam rods laying around, so went ahead and used them. Didn't see the point of H beam rods with a cast iron crank, so I bought a Scat steel crank.
But I painted the engine black, so it looks stock, except the stainless hardware and aluminum timing cover.
idahovette
Weiser Idaho
Perry
K20-K10
The 2,19s and the 1.88s make a WORLD of difference, it really wakes up the big blocks, especially with the right cam
Wumbo
Illinois
Rob
@Wumbo which cam? Hydraulic?
Yeah, hydraulic. This is my daily driver, so I kept it mild.
https://www.lunatipower.com/voodoo-retro-fit-hydraulic-roller-cam-chevrolet-big-block-262-270.html
Voodoo Retro-Fit Hydraulic Roller Cam - Chevrolet Big Block 262/270
Retro-Fit Hydraulic Roller Cam. Very strong increase in low RPM torque and power. Works well with OEM style injection, great inboard/outboard marine cam for economy and sking.; Advertised Duration (Int/Exh): 262/270; Duration @ .050 (Int/Exh): 211/219; Gross Valve Lift (Int/Exh): .550/.550; LSA/ICL: 112/106; Valve Lash (Int/Exh): Hyd/Hyd; RPM Range: 1400-5400
Wumbo
Illinois
Rob
That, the 3 angle valve job, and undercut stems should all work nicely together :Big Laugh:
bad face
