Bed Support "Cross Sill" Options
scrap--metal
MN
Calvin
'85, '81
K10, K20
My truck needs rear bed support rails, or "cross sills" as LMC calls them. It needs them bad... They're currently unavailable through LMC (backordered). Are there any other sources for reproduction parts?
I checked Brothers (now Holley) and AMD, but couldn't find the parts from either of them. Certifit (a.k.a. sorta-fit) didn't offer them in their catalog either. Please let me know if any of you are aware of any other sources.
Ultimately, I'm trying to keep my K10 on the road for a little while longer. I haven't been able to find a usable bed up here for less than $500. One guy wanted $750 for one needing work to be usable. If I'm going to need to cut and weld, I might as well do the work to the rusty junk I already own. At least that's my current frame of mind.
Got any pics of what you're working with? I work at AMD, we only offer the rear cross sill because customer typically need the whole floor if they're replacing supports/sills.
Rear cross sill:
And also one you can use as a patch if needed:
Camar068
Kentucky
10 yrs Air Force
buddy took some U channel and cut/split/welded them to length/height. I'm not a welder so it's not an option for me....have to farm it out.
scrap--metal
MN
Calvin
'85, '81
K10, K20
What I'm working with is essentially junk. And it's even worse than I thought. :( I hadn't been under the bed since last fall. The rear sills, partially pictured below, are what I was initially asking about and looking for. The front sills are now junk as well. And the rear most cross sill, as offered by AMD, is also necessary.
I can't justify investing in all those pieces to keep this bed in service. The bed sides are junk and it's got its share of dents and dings inside. I'm confident that I need to find a different bed.
etc86
Australia
eden
was a 292 now 4l isuzu diesel
Hey guys, hope everyone is ok with me jumping in. I’m currently going through a similar process with my 75 c20. I’d buy them but I live in Australia and freight is a killer so I’ll be fabricating them myself. Does anyone know the measurement from chassis to bed floor at the front of the bed near the cab and above the back wheels? I’ve asked in other forums but helpful people keep telling me to buy them. Thanks in advance.
75gmck25
Northern Virginia
Bruce
I have a 1975 Truck Specifications document in PDF that might have some of the measurements you need. However, when I tried to attach it to my post it was too large.
I’ll see if I can compress it or create a zip file that can be attached. On my iPad right now and I don’t have the software I need to change the file size.
Bruce
etc86
Australia
eden
Thanks for that Bruce. I found those myself and came up with a rough measurement. I’m looking at roughly 2.9 inches for the main cross sills and I’ll work out the Center ones from the chassis height difference. I’m surprised that nowhere has the actual specs for them though.
etc86
Australia
eden
Thanks for the tip Rusty. Unfortunately they only go back to 1995 though so no love. But with the scale drawing I found I should be pretty close. A guy on another forum got back to me about it as well and he’s going to measure his on the weekend. I’ll make it work somehow, the rest of the thing is put together out of luck and persistence so may as well continue the theme.
daven
PA
DAVE
Try NPD
etc86
Australia
eden
NPD was a no go. I really just need a height. Buying anything will cost more in shipping than it’s worth really. I’ll either get some bent up or if they’re pretty close to a standard top hat/purling size I’ll use that and then shim or shave as needed. I’ve pretty much got it figured out though. Cab height and bed height will be the same off the chassis close to where they meet. I can work the rest out from there.
Rickf
Grafton NH
1974, 1954 & a 1937
If you're not looking for a 100 point trophy, what about box/rectangular tubing? I will neither confirm or deny I've used PT 2x4's.
DanMcG
Central NY
k10 k10
I'm a little late to the party here, Are you looking for dimensions for these cross sills?
A quick measurement looks like 3" and another is 2.9" I can look closer if you need more info.
etc86
Australia
eden
Never too late. Even if I didn’t need them, which I do, someone would have eventually. I was pretty much at that myself but nice to confirm. So the one’s between the wheel arches, are they around 1.5?
Hard
