are quadrajet baseplates the same flavor?
Taylorb27
North Dakota
basically wondering if rochester calibrated their baseplates like they do bodies on the qjets. i went to swap idle mixture screws from a qjet from 72 model carb to my 84 model carb and the thread size and pitch is very different. wanted to swap due to the fact that my 84 model has the odd head screws or "double d" head. just wondering if i swapped the whole baseplate if it would throw off some sort of calibration.
75gmck25
Northern Virginia
Bruce
The Quadrajet’s used in cars changed in ‘75, so you see references to pre and post ‘75 (usually referred to as modified quadrajets). However, they delayed that change in trucks to about ‘80 (not really sure of the year). Bottom line - it’s unlikely you can swap base plates between ‘72 and ‘84.
Bruce
yevgenievich
Place
Name
Year
Model
Size
Early base plate has different primary shaft length. But early base plate will work with later shaft if a bushing/spacer is added. I had to use later model shaft on older plate to get electric choke to line up. Late model plate will not work with early shaft unless milled.
