hinkv10
- Nov 8, 2012
- ct
- craig
- v10
I've just about got my 87 v10 on the road and I need help getting a couple of things back together:
My shift indicator was broken when I got it and didn't have a wire attached. Does anyone have a pic showing how it attaches to the column? The new one has a clip attached to the wire but I can't seem to find where to hook it.
My second issue is I tore down the steering column and tightened the bolts and replaced the shifter spring. My highbeams were inop when I got it and I assume the rod for the high beam was not installed correctly. I put it back together the same way it was and of course, it still doesn't work. Does anyone have a pick on how that goes together? Does the rod go through the piece that always falls out?
A bonus would be if anyone has a pic of the spring that goes into the black cam. After I put it back together my steering wheel no longer locks. I'm going to be away for a couple days but would love to get this truck on the road right after Christmas. Thanks in advance
