Almost done, need help with highbeam switch and shifter indicator
hinkv10
ct
craig
v10
I've just about got my 87 v10 on the road and I need help getting a couple of things back together:
My shift indicator was broken when I got it and didn't have a wire attached. Does anyone have a pic showing how it attaches to the column? The new one has a clip attached to the wire but I can't seem to find where to hook it.
My second issue is I tore down the steering column and tightened the bolts and replaced the shifter spring. My highbeams were inop when I got it and I assume the rod for the high beam was not installed correctly. I put it back together the same way it was and of course, it still doesn't work. Does anyone have a pick on how that goes together? Does the rod go through the piece that always falls out?
A bonus would be if anyone has a pic of the spring that goes into the black cam. After I put it back together my steering wheel no longer locks. I'm going to be away for a couple days but would love to get this truck on the road right after Christmas. Thanks in advance
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
It just clips to the plastic piece, there's no set place for it to clip to. I usually just put the shifter in first, pull the indicator all the way down and clip it to the column piece.
RetroC10Sport
Jay
pontiac aztek
Spring installed with set screw.
Full lock, key in accy.
Key in wheel unlock.
Unlocked, key in START.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
I don't have any pics but the toothed slide below the black cam has to be hooked onto a pin in the lower part of the steering column.
hinkv10
ct
craig
v10
awesome! thank you. I can't wait to get back and fix er up.
RetroC10Sport
Jay
pontiac aztek
If I can find all my column parts, I'll show how to install the high bean crap.
Awesome pics Retro. I'm going to copy that info to the column thread when you are done here. :)
Posted from mobile...
ebob14
