Adding oil to a 10 bolt axle
Ty'1987
Lansing, mi
Tyler
Where is the filling location? And how much oil should I add?
Rear axle? There's a square-drive fill plug on the passenger side of the diff. Take it out, fill it up until it starts to run out the fill hole. Total capacity is 2-3 quarts.
If you have the cover off and the fill plug won't come out, fill a couple 1-quart ziplock bags with lube. Then carefully stuff them in the diff and install the diff cover. Drive.
roving4s
America
xxxx
Never heard or thought about that.
austinado16
Central Coast, CA
1990 w/307k miles on the clock
GMC V1500 Suburban SLE
5.7L TBI/4L60/3.42's
Nice. Add a pound of hamburger and women's pantyhose for the ultimate in quiet differentials.
I'd reckon those ingredients would also make a good substitute for posi additive.
MrMarty51
Eastern Montana
Martin
NAW, 75-90 gear oil mixed wit bananas.
A friend bought a pickup, put it upon a hoist where He was working, looking it over, walked to the back, had a weird odor, pulled the differential cover, when He got done :puke: ing from the smell a rotten bananas mixed wit gear lube, He cleaned it out, put the cover back on, refilled the differential wit fresh 80-90, He had a howl in the rear gears. Imagine dat. :idiot::happy175:
Yep, I've heard bananas will quiet down a humming rear end. That and saw dust.
roving4s
America
xxxx
I know what would work hella better than gear oil. Those of you that carry/shoot how about using some Frog Lube ? :)
Washington
Never heard bananas. That’s bananas!
And great tip on the baggies of oil. Seriously. Ida never thought of that. But no reason it wouldn’t work and well, at that!
michaelmarine53
