77 K10 LS Swap
Madhorn
AR-Arkansas
Ken
5.3/NV4500/NP205/4:56 gear/35in tires
Just received the Loctite 680!!! Out to the shop me go. Outer bearing races installed ready for 24 hour cure.
Madhorn
AR-Arkansas
Ken
Back on all 4 and rolling. Alignment Friday morning.
Madhorn
AR-Arkansas
Ken
Parts for next revision of day time driving lights. One port gets plugged the other gets oil pressure safely switch to control low beams. This way the low beams come on when engine starts.
hoagster
Air Force Supporting Member
California
K10, 1500
5.3l
Was able to get a couple hours of work done today. Axle cleaned and painted, old u-joints pressed out and tie rods and drag link assembled. Next is installing new u-joints and ball joints.
Looks like you stole all my parts! Looking good
Camar068
10 yrs Air Force
looks great man.....keep the pics coming.....enjoy them
Madhorn
AR-Arkansas
Ken
At the alignment shop
Madhorn
AR-Arkansas
Ken
All went well with the alignment. Camber on both sides was with in a half degree. Was worried about the passenger side with that off set bushing. Good for another 20 years.
Madhorn
AR-Arkansas
Ken
Installed oil pressure switch and wired it into the relay control ground for the day time drive lights. Now the lights come on when the engine starts.
Poppy 87
Bloomingdale GA
R10 Silverado
In stalled oil pressure switch and wired it into the relay control ground for the day time drive lights. Now the lights come on when the engine starts.
Pretty cool setup. Is that also where you actually monitor the oil pressure as well?
Sent from my XT1254 using Tapatalk
Madhorn
AR-Arkansas
Ken
Oil pressure is read at the back of the block where the factory sensor was installed.
Camar068
10 yrs Air Force
Nice...perfect place for it
Madhorn
AR-Arkansas
Ken
Had some time today to clean up the rear differential.
Poppy 87
Bloomingdale GA
R10 Silverado
Not a lifted 4x4 guy, but in my experience, isn't the driveshaft slip yoke supposed to be at the transfer case end? Have not seen it installed with that orientation?
Madhorn
AR-Arkansas
Ken
It can be at either end. I am running a double cardan joint at the transfer case so the slip joint has to be at the differential.
Madhorn
AR-Arkansas
Ken
My attempt at making coil covers.
nixon22
