6/8" lowered and LS motor clearance
347strokin
Vancouver Island
Jon
R15
Does anyone foresee an issue with running this low and clearance with a 6.0 LS motor? I seem to read lots of talk on oil pan and ground clearance heights. And does an LS motor hang lower than a traditional small block?
My truck is what's in my signature.
Thank you.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Thank you.
It will depend on your mounts. Tejas Steelworks mounts are optimal for lowered vehicles, as they move the engine up, so a stock truck oilpan will be flush, or just above the factory 2wd cross member. They do move the engine forward a bit, so you'll need to run e-fans and get a new driveshaft made, most likely.
Camar068
Kentucky
10 yrs Air Force
Thanks for the info foamy. Those got me thinking for my install.
347strokin
Vancouver Island
Jon
R15
Beauty, and I see they've got a ton more info on C10 LS swaps. Thanks. :cheers:
Camar068
Kentucky
10 yrs Air Force
Do you know if it raises it up enough to give more room for the stock AC compressor w/o having to notch the frame? I'll call them tomorrow and ask if you don't know.
347strokin
Vancouver Island
Jon
R15
It looks like Dirty Dingo mounts will also clear a stock LS truck oil pan and possibly your AC compressor?
http://www.dirtydingo.com/shop/index.php?cPath=359_362
It states:
* These mounts will clear LS Truck low mount A/C but will not allow the engine to slide back, they mount against the a/c compressor bracket
Camar068
Kentucky
10 yrs Air Force
Thx, sorry for hijacking your thread a bit.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
The compressor itself will clear. As far as hoses go, you can get 90* fittings from ColdHose that will let it clear, or you can modify the factory LS hoses, but that will require a small clearance in the frame to clear the compressor fitting.
wilson79
