4L60E deep stock aluminum pan w/drain upgrade?
Camar068
Air Force Supporting Member
10 yrs Air Force
Are there models of the 4l60E pans that were stock, aluminum and with a drain plug?
Looking at options. Looks like I can get a normal pan for $30-50 with a drain plug. If I can go to a junkyard and get one that's thicker w/drain plug, I'll go that route if it's reasonable.
NickTransmissions
Las Vegas
Nick
I’m not aware of a production aluminum pan for these transmissions but the aftermarket pans like what you saw are pretty good. Some of them are simply remanned factory pans with drain plugs added.
You can also add one to yours either via drilling then welding a nut for a factory drain plug w/seal or an aftermarket drain plug kit from Superior Technologies
duncan_schawalder
