1994 S10 1Ton SAS
Moderator
Oh and I don't know anything about the Ford 205. They might have had a 29 spline input?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Ive heard similiar stories. Would require a coupler for the spline differences. Or a divorced case
Vbb199
Salisbury NC
Vince
Took her for a spin tonight..... started in 2 high....
Did good, spins the tires, moves, etc.
Then hit 4 high, climbed a maybe 2.5 or MAYBE 3 foot (doubtful) 90° slop.... locker kicked in, drivers tire spun maybe 1/8th of a turn, grizzly kicked in, she pulled.
Climbed the hill... no prob, just needed some throttle.
Switched over to 4 low, i feel a little torque steer to the right.
pulled my drivers tire up to a stump, also about 2.5 feet tall, light throttle, it climbed right over.
Threw it in reverse, went back over it! Excellent!!!!
Looking forward to rhe uwharrie trip
Vbb199
Salisbury NC
Vince
Took my PS pump valve back apart and decreased the presssure a tad to >1400 to like 1100-1200, pump no longer slobbers out of the cap
On the right was the previous HP fitting i was running (drill out)
And on the left is one im running now (slightly large than stock)
Vbb199
Salisbury NC
Vince
Next up was the angle iron to raise the 4x4 shifter up a tad, then tacked it to the floor for trial..... worked fine on the first try.
Also had to shorten the shifter since it was gonna wack the AC vents and the center console.
Got the carpet back in, and at least my seat, and put the squarebody suburban's np208 cover on. I have a functional shifter!!
Vbb199
Salisbury NC
Vince
Tried to climb a tree with 1 tire i got about 2 foot up the tree, then i lost traction and slammed down o the ground hahahahahah
Turbo4whl
Downingtown, PA
Wayne
Vbb199
Salisbury NC
Vince
Seems legit hahahahaha
Vbb199
Salisbury NC
Vince
Pretty much the only thing left that i know of is fixing the rear brake line leak.... and im ready for next weekend.
78C10BigTen
pennsylvannia
C10 BIG TEN
Holy crap you washed it to?!!!
Vbb199
Salisbury NC
Vince
Failed to add, i also welded D rings on
Vbb199
Salisbury NC
Vince
A little stump rippage with a nice low 4x4 and the winch
bajadiver
