1994 S10 1Ton SAS
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
It's a "pre vortec" vortec motor. Still uses a dist, no coils
Vbb199
Salisbury NC
Vince
Well hell that clears it up. Lol
I wanted to maintain a low COG, small lift, but still be able to clear big tires for trail riding.
I think I won this time.
Edit: it's got a 4" lift from my parts suburban.
Not to pat myself on the back, but I figured this out just right where it clears the 39.5's with a tape measure. Not too bad. My little cad drawings were a little off. It clears those tires more than I expected.
I'd stick with the 4.3 too. They make good grunt for what they are, and it's already in there to boot.
A little perception for you, it's not as big as you might think.
Yeah, but you're tall...
78C10BigTen
pennsylvannia
C10 BIG TEN
Youve done amazing work on it that i could never do. I applaud you! You deserve that 40oz lol
78C10BigTen
pennsylvannia
C10 BIG TEN
Don't even speak of that here on the grounds of b rate hillbilly customs, everything will fall apart and quit shifting
It was only a joke about your 4...40's... get it lol
Vbb199
Salisbury NC
Vince
It was weird climbing in the seat.... Boy what a change
Vbb199
Salisbury NC
Vince
I know lol, I didn't add any laughing faces to that so it seemed serious. My bad lol
Vbb199
Salisbury NC
Vince
So on lunch I walked up to the house and while munching on my pizza, I started looking at the overall progress... Steering angle is very nice. Won't need high steer I'm almost certain.
Rear drive shaft however is gonna need some work. When I welded down those 5/8 pads on top of the original 14 bolt bump stops to adjust for the 38.5 Centerpin distance, after the fact I noticed the original spring perches in the axle tube probably kicked the pinion up 5 or so more degrees than my pads do.
The driveshaft hanging is obviously on the ears of the yoke at the tailshaft.... So I think the simplest solution is to cut the factory bump stops I welded pads to off, and spin the pinion up until it's at the right angle for driveline engagement. Not a big deal.
Front I still can't determine because the s10 crossmember is keeping the driveshaft from hanging down. I still have to modify that.
On the list now is to bleed the s10's brake system clean (fluid is filthy, I never changed it or maintained it, just drove it and added it)
I probably boiled it a few times locking up a caliper on the rotor.
I have the front and rear brake extensions, none of that is a big deal.
Front driveline I might extend and balance myself. That'll never see high speed anyway.
I have access to a lathe (obviously)
I still have to put tubes in the front tires
Need to finish the steering arm, and need to buy some 1.5x.250 DOM and heims and setup my drag link (yes I know those are meant to be ran in double sheer)
And I need to buy another ps pump (I cut mine out long ago)
And get a junkyard steering box.
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
It’s all coming together and rather quickly. Your doing great man, keep it up!
Vbb199
Salisbury NC
Vince
I found out earlier today while I was cleaning up the "shop" that the soon to be Mrs brown can't get up in the s10 :hahano:
So I guess I'm gonna need to build a step on that too!
xXmutantXx
