1994 S10 1Ton SAS
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10, 99 Silverado
This makes me wonder how @Arkansas_V8 's tcase repair held up...
Well... Ya see, I was gonna be a gentleman and let Him have this adapter, then we both realized, it's a no go. This is a 700/208 adapter.
He needs a th400/208 adapter
Sent from my SM-G965U using Tapatalk
Vbb199
Salisbury NC
Vince
I never went back to a follow up, but I did the head gaskets, got it all buttoned back up, seemed to be a premature failure... Water jacket broke over into the head gasket, not the other way.
Anyway, truck runs well, I have 5 brand new all terrains for the 89 burb, so soon its time to get the suburban underway with getting it on the road, and taking the s10 off.
I also want to add, the tire sheered the lug studs off, and I lost a tire on Christmas day.
That was nice.
But the truck is running again.
Poppy 87
Bloomingdale GA
R10 Silverado
Damn, what cause the lug stud failure? Corrosion?
Sent from my XT1254 using Tapatalk
Vbb199
Salisbury NC
Vince
When I did the head gaskets, I took the starter out, it's easier to take the starter without a tire, (the solenoid wire was part of the harness I was trying to move out of the way)
I put the tire back on, hand tightened the lug nuts, never torqued them.
Its my own fault.
Crazy thing is I drove like that for a week
Vbb199
Salisbury NC
Vince
Oops ,better have another Miller High Life after that one!!!
Buddy.... I had ONE good lug stud (it was the same lug stud I didn't have a lug nut for) , I bolted it up, drove it home like that, went to my parents for the pre Christmas gathering, took a mighty dose of goldshalger with my dad, we went to my grandfathers (he's a walk away) drank a 12 pack and several 40's, boy, I was destroyed in Christmas.
Moderator
Letter from the editor:
NP208 and it's adapter will bolt behind a s10's 4l60e.
SUCCESS!!!!!!
There ya go!!! I assumed that would work, but wasn't 100% sure.
Vbb199
Salisbury NC
Vince
That means.... If a np208 will work, a 90-91 np241 will work, now I just need to find one
Vbb199
Salisbury NC
Vince
Goes without saying, anyone reading this, I need a np241 from a 90-91 burb or blazer.
Moderator
Ever seen the inline VSS adapters used for like TPI swaps and stuff? I wonder if one of those would work. I have no idea what pulse per mile your stock VSS likes to see, but I bet that info is easy to obtain.
Vbb199
Salisbury NC
Vince
I have not.
I thought about cannibalizing my s10's t case for the vss and fitting it up to the np208 somehow, but I'm interested in what you're talking about.
Edit: not the vss, but the reluctor ring and sensor out of the t case in the s10
Johns C10 Hubcap
