1987 V20 headlights
Wolverine
Montana
C.A.
V20
Needing replacement headlights on my 1987 V20, the existing ones are clearly marked, "2A1" on upper set low beam, and "1A1" on lower ones high-beam. All the parts sites I am looking on are showing one all around replacement headlamp "guaranteed to fit" with no differentiation. What pertinent information am I missing ??
Needing replacement headlights on my 1987 V20, the existing ones are clearly marked, "2A1" on upper set low beam, and "1A1" on lower ones high-beam. All the parts sites I am looking on are showing one all around replacement headlamp "guaranteed to fit" with no differentiation. What pertinent am I missing ??
im guessing that differentiates the intended use of the lamp. if you are using halogen, id go to the auto store and buy a high and lo beam for an 87 with quad head lamps. I cant imagine they had other options. The low beam probably has a feature to reduce glare at the tip of the filament while the hi beam probably does not
codfish
Drive a hybrid. I NEED your gas!!
Newfoundland
gary
Where I live I had trouble finding replacement headlights for my 84, with quad lamps. When I did they were $20 a pop. I’m cheap. I held off buying them. While in Walmart one day I wandered down to the auto isle and found my headlights, both upper and lower, on clearance for $3 EACH!!!
Score
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
The upper bulb is a low and high beam (3 prongs). The lower position is high beam only (2 prongs).
87POPS
