1987 Silverado Help!
AMW
Adrian
R10 Silverado
Ok i have a 1987 silverado with the 305 and automatic transmission It runs and starts fine but im having a problem with it bogging down or spitting and sputtering when i go wot down the road it also seems like it doesnt have much power Im sure my timing is off i set it but am not a expert lol the truck has new plugs, coils. o2 sensor, distrubitor, fuel pump, starter, radiator. I bought this truck off a friend for 800 $ he had it but couldnt find out what was wrong so now im gonna try lol
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
How about the fuel filter? To set the timing, warm up to operating temp, you need to disconnect the timing connector on the firewall, near the brake booster. It a single plug(like the o2 sensor plug) with a tan wire. then loosen the distributor, just enough to turn it, with a little resistance...the bolt is 9/16.
Hook up a timing light, and set it to 0 degrees, shut the engine off. I would recommend disconnecting the battery for 15 seconds before satrting the engine, this will erase the memory in the ECM, and give it a "clean slate" to start over from.
Dont forget to plug the timing wire back in, or the ECM will not be able to control timing.
AMW
Adrian
R10 Silverado
yeah the fuel filter was replaced aswell the oil was changed my friend put 10w30 in it when he had it im gonna put 10w40 high mileage in it once i get it running good
Jims86
Patterson,Ca
5.7 TBI
Ok, when the pump was replaced, was the rubber line on top of the pump replaced as well? That particular hose is one of the main causes of problems with TBI trucks, and from what the symptoms you describe, it sounds likenthere is only enough fuel being delivered for idle. Also, Just for the heck of it, check the spark plug wire routing after you set the timing.
AMW
Adrian
R10 Silverado
Im not sure about the fuel pump rubber line thing my friend when he had the truck he replaced everything i wasnt there, far as the spark plug wires there was a local mechanic he said the wires were in wrong order so he put them to the way they were supposed to be but he still said the timing wasnt right he did it by listening to the engine i dont know if this will help anyone fighure out what is wrong but also when im in drive or reverse if i sit too long not moving or going slow the engine will stall out but if it is neutral just idleing its fine, Also none of my guages work except my gas guage and battery plus the clock all others dont work not sure why but
AMW
Adrian
R10 Silverado
Here are some pictures so you can see more of what it is
AMW
Adrian
R10 Silverado
Anyone might know what the problem is with the truck please post lol im stumped with the truck plus i have plenty of pictures to show of the truck to help fighure out whats wrong.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Sounds like it might be vacuum leak to me. Check all your hoses and the front/rear seals on the intake. A vacuum gauge would really help.
AMW
Adrian
R10 Silverado
where would the vacum be at mind you i have not alot of experiance with motors just little
AMW
Adrian
R10 Silverado
I do know tho that there are 3 little hoses unhooked there both dangling freely two are near the distrubitor and the other is on left side near valve cover if you look at these pics i put up they are there
crazy4offroad
Curt
K-10
350/SM465/NP205
I cant tell from those pics but if you got vacuum lines off that is 90% of your problem I bet. Try to figure out where they go, or in the meantime try plugging/capping them and see if it improves any.
AMW
Adrian
R10 Silverado
ok ill do that tomorow when i got the truck they were just dangling i didnt see where they coulda gone at time so i left them but ill deffintly try to find out two of the hoses are really small in diameter the other one near the left valve cover tho is larger
crazy4offroad
Curt
K-10
350/SM465/NP205
Yeah the smaller ones look likee hard plastic lines, a rubber line may slip on one of those. If not sure cap the small ones and plug the larger rubber ones.
AMW
Adrian
R10 Silverado
also where does my pcv hook to cause right now its just open on top of valve cover ?
crazy4offroad
Curt
K-10
350/SM465/NP205
Hopefully one of the other guys can help, I'm a carb guy and I think yours is tbi. If I had to guess I would say there's a large connector on the base of the throttle body that the large vacuum hose hooks to.
duckslayerja
