1979 454 C10, Factory Air
1979big10
Colorado
Howdy. I know this is my first post, but been using the forum for over a year to work on the 1979 C10 Big10 I bought out of a field in eastern CO last year. I have searched the forums have read up on the pros
I absolutely love the truck. Shamrock Green Metallic, 454/TH400, 8' bed. Silverado, factory cruise, A/C, but manual windows. I bought it non-running and have put about 10k miles on it in the last 12 months.
The factory air system is partially intact- the condenser and the evaporator are there (in unknown condition)- but the compressor, accumulator, and hoses are gone. I am unsure if this had an axial or radial compressor- I see conflicting info on LMC truck as well as the forums.
I want to add A/C back this spring, but am debating what route. Do I get a modern kit from Vintage Air, LMC Truck or Classic Auto (that uses factory ducting, not underdash), or do I build the system with factory components? From a quick look, Rock Auto and or LMC should be able to get me all the components and it would be a good bit cheaper than a Vintage Air or similar kit. Welcome any input or suggestions from people with experience here.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
I would run factory air if it was mine... My cab had an old aftermarket AC poorly hacked through the firewall, so I went with vintage air for my build. The VA set up is well thought out and seems like quality stuff, but I don't think it has the power of the factory units.
IMHO the only bad part with factory air is the cable operated controls, I snapped the ends off of my control levers a few times when my SB was my daily driver. I could have probably avoided that with some lube and maintenance though.
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
You can put together an entire kit for less than VA charges. That's what I'm going to do. Comes out less for both front and rear controls (crew cab).
I'm going that direction bc crew cab and non ac truck.
Still going to use that big boy sanden compressor for example.
Old Guy Bill
KY
Bill
To me it depends on the condition of your existing factory components..
Most of mine were missing and the box on the firewall was damaged badly.
fast 99
Spokane, Washington
Factory AC is way better except do not use either one of the original [R4 or A6] compressors. Sanden is a modern design and I believe there are conversion kits to mount and plumb it. There's likely a complete under hood kit.
It takes a little searching, but there are kits to adapt and replace the old compressor and lines with newer compressors (usually Sanden). For example, the Pro6ten is an R134a Sanden compressor packaged as an exact bolt-in replacement for the A6. Some HVAC sites also sell adapters to bolt onto a Sanden so you can attach stock GM hoses.
General guidance
- original evaporator is fine if it has no leaks. Also make sure the evaporator temp probe and low temp cutoff works. That is what keeps the evaporator from freezing.
- original condenser is an old design, but so large that it may work fine with R134a. Parallel flow condenser would be more efficient, but you will need adapters or new hoses that fit the metric connectors.
- accumulator and/or filter/drier must be new
- original hoses should be replaced by new barrier hoses (however, old ones might work fine for a while)
- all new green o-rings
- pull vacuum for 30 minutes or more, and start with R134a charge to about 75% of recommended R12 amount. Tweak charge from there, based on pressures.
- most new compressors are pre-filled with PAG oil. All other components will need to be flushed to remove incompatible oils.
- R134 charging port adapters may be part of a new compressor, spliced into new hoses, etc.
- many sites recommend also adding a high pressure cutoff, but I have never seen pressures that were much higher than R12 pressures
- make sure your fan clutch is working, so you get good air flow.
1979big10
Colorado
Thanks for the help. All of that info has been great.
So I’m looking for a Sanden, drier/accumulator, hoses & belt at a minimum. Need to figure out adapting brackets and hoses.
This is what is there, looks like most of the bracketing is missing. From a quick glance I think Dirty Dingo has brackets to adapt to a Sanden 508, so I’ll probably go with that. But I welcome any input on vendors and sourcing these parts.
1979big10
Colorado
On second glance, the Dirty Dingo bracket does not accommodate v belt compressors or 454s. Hoping to not convert the belt system, so if anyone has recommendations for brackets, I’m all ears
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10, 99 Silverado
General guidance
Is this an AI copy paste ?
No, but why do you ask?
I’m not sure whether it’s good or bad if you think I am AI!
I’ve been fixing and tweaking the A/C on my ‘75 K25 since about 2002, so it’s a long painful history.
The latest set of brackets I’m using for the Sanden compressor are made by Alan Grove (purchased from Summit). I used one version with the iron exhaust manifolds, and then switched to another version that worked better when I added headers. For the SBC think it was the 119L bracket to mount in the stock location but would have to look for my paperwork to verify.
Vbb199
Salisbury NC
Vince
Oh I only asked because the format which you replied in looked suspiciously like AI content. Not that YOU are AI, but you copy pasted google AI
The dashes at each point like bullets starting with the words "general guidance" looked like AI
Plenty of people do it every day to make themselves appear like theyre very knowledgeable, I was just wondering. I KNOW you know your stuff, so to see what i believed to be AI copy-pasta was shocking, to be honest
1982GMCC1500
Lyndhurst,N.J
Robert
C1500
Better off with an A6 ( IMHO) and stick with R12 (It's out there)
The downside I found with the A6 is that all the ones at a reasonable price were rebuilt, and the first two I tried developed “Black Death” inside after a short time, which filled the system with black granules.
I’m also not too crazy about the size and weight of the brackets used to mount the heavy A6. They work, but hang/cross over the intake and get in the way. YMMV
duncan_schawalder
