15s and 16s
Pmac
Dowling
Pete
1980 & 1981
C2500 Suburban & C1500 Pick Up
350M & 305H
Are there any bolt on 16 inch wheels that will bolt on the 5 lug bolt pattern?
'81 C1500.
Thanks.
ali_c20
Austria
Alexander
C20, K5
Yes. Summit alone has 489 different wheels and I think there are more out there..
Moderator
Although uncommon, there were factory 16's available for C10's. They were 16x5" though.
oldretiredafguy
N. Texas
1988, 1988, 1991, 1983
350, 350, 350, 350
I bought some 5 lug 16” wagon wheel style rims from Discount Tire for a trailer. They had to order them overnight, but they are available.
79dentside
Kansas
Brandon
GMC Sierra Classic
These are the exact wheels that I am running. I have 16x7’s up front and 16x8’s out back. I bought them knowing that I was lowering my truck and proportionately, I thought 16’s would look good. I like these wheels, my only complaint is hubcap versatility. I was hoping you could slap some corvette rally caps on or something just to change up the look, but the center is a different diameter than like a 15” corvette Rally and only accepts certain hubcaps or at least that is my understanding from the test hubcap that I bought that doesn’t even snap it. I did find some hubcaps that say they fit wheel vintiques 12 series, but I ended up making custom mounts to hold 3/4 ton poverty caps. I also recently found a set of 1/2 ton poverty caps that I liked the diameter of better so I just re did my mounts yesterday for those.
Here it is with one of the 3/4 ton caps:
Here is one of the rear 16x8’s with the smaller 1/2 ton cap after I made new mounts:
78C10BigTen
pennsylvannia
C10 BIG TEN
They look good on that!
Pmac
Dowling
Pete
1980 & 1981
350M & 305H
Thanks! I have 3/4 GMC poverty caps to modify - I will start the search to determine the cost of shipping up here.
This is just what I was looking for.
Pmac
Dowling
Pete
1980 & 1981
350M & 305H
Thanks to all for the help.
79dentside
Kansas
Brandon
GMC Sierra Classic
Oh how funny haha. I had to get a little creative on the hubcap mounts for the 3/4 ton hubcaps, but you can get them to work. This is how I mounted the 3/4 ton caps.
Basically I made 2 fingers out of 1/2” conduit hold downs for the cap to hook on and then a slip over point on the opposite side
Takes some patience if you do it this way, but I got it to work just fine.
ldale91
