Remove O2Sensor
Mango
JacksonWyoming
Gil
Stuck O2 sensor 200,000 miles on a 89 burb
legopnuematic
Licensed Junk Dealer
MO
Spencer
If it’s no good and going to be replaced, cut the end off then put a normal socket on it and try that.
Edelbrock
Earth
Grumba
K5 Blazer
If there is room, try getting in there with a mini pipe wrench. Or maybe a basin nut wrench.
Sad Sack
Omaha, NE
Goober
C15
My O2 sensor tool is a 7/8" 6-point box end wrench, works much better if space permits. Goop up the new one with anti-seize.
