Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Wish I had done this earlier. It was super easy and cheap.
Yeah, I've thought about rear floods just for pulling boat out of the lake in the dark. I see how easy to add into backup though. Definitely shouldn't take out one of those trash cans.
Z28 Guy
mississippi
Jermaine
Snapped a pic after getting the injectors fixed. Car quest sold me the wrong injectors. New ones from another parts store popped right in place. Now im wanting to add a smallish size tach to the truck as im getting it ready to pull my Z28 to the track.
Any pointers on a small tach recommendation ?
Sad Sack
Omaha, NE
Goober
C15
Slowly but surely...
Meet the other half:
Gettin' there.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I like the bosch on on my 82 I mounted on the steering column. I think it's about 3 inches. It's held up for about 6 years now. Got it at advanced auto in town.
ChuckN
Bellinham, WA
Chad
Not much going on right now- been kinda busy. Got to thinking about some more carb tuning. The 70/37 metering rod is a touch too rich, the 73/37 is a little too lean. Found a rarely known 71/42 that I’m going to try out directly from Edelbrock. While I was at it, ordered a fender cover from them and a classic Vic Edelbrock t-shirt and got free shipping.
Haven’t gotten to the Bilsteins and the spring spacer as of yet- got notification that the kitchen cupboard guy will arrive soon so we went into tear down mode to be ready for demo day.
1lejohn
texas
john
k-1500, 2500 HD
Thats what I have on my truck. I have mine screwed into the metal. The tach housing rotates to the right when in gear. It was blocking the speedo when it was fixed stationary in the middle. The tach is over 5 years old.
pinballlarry1
Kalispell, Montana
Larry
250 6 cylinder
Worked on the driver's side rear stop lamp assembly. Two people told me it was not working, but of course it always worked fine in the driveway. Anyway, took it apart and cleaned up the ground connection to body sheet metal along with the two contacts at the bottom of the lamp socket.
10MM hex head on the ground screw, small flat blade to scrape the base contacts. There was a lot more corrosion that I expected, and I hope this fixes the intermittent failure.
The wasps thought the truck was a very sweet hideout also. They are always finding places to nest during the summer.
All of these were up inside the body layers above the rear lamp assembly. Now I will have to take apart the passenger side and clean it out also.
UPDATE: Passengers side lamp socket was corroded as well, it cleaned up nicely.
More insect nests in the nooks and crannies of the passenger side, got them all out.
There is no ground wire connection on the passenger side.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Waiting on Safelite. Appointment is 8:00AM to 5:00 PM
metro247
