Yes.Well, let's assume the valve is good. Maybe a silly question, but are the longer shoes on the rear ? Rear is the secondary shoe position which is the longer shoe.
I have looked at these and I'm fine with it. I have some questions on the plumbing. Simply add this like you said with no other changes? I can leave the existing plumbing as is?There is always some confusion between “Combination” valves and
“Proportioning” valves…
Get a Wilwood valve similar to this one, make sure of the fitting size.
Mount and plumb it into the rear brake line, and adjust it to where the rears don’t lockup.
This is very popular in circle track racing.
A) No idea. I replaced all the existing stuff with new parts the way the old stuff was assembled. B) The new stuff is stock replacement parts and looked just like the old stuff. I don't take wheel cylinders apart to verify size.A few clarifying questions:
Did the problem exist before replacing everything?
if not did you verify your new wheel cylinders and calipers had the same diameter pistons as the originals?
i disagree, if everything is checked five times , then it couldnt be the case unless your tires are grossly different in pattern size and stickinessI have checked them five times. Seriously, five times. Everything is "perfect".
brake hose diameters swell in and restrict, uncle tony showed one that had a pin hole diameter to through itCheck to see if your rears are dragging during normal driving. Go drive like a mile without much braking and see if the drums are hot.
I fought rear brake drag when I did my brake job. Changed the master and brake pads and shoes, nothing else. Ended up with brake drag. Nothing fixed it but driving it, I still don't think it's 100%. But the drums aren't 400 degrees anymore.
the backs get pressure first, the to overcome springs and begin their self-energiziing design, then the fronts have less distance to move to apply, and once the rears were beginning the fronts are getting the pressure and they begin braking, so it feels balancedBefore getting all crazy and reconfiguring things and cutting into stuff, have you tried jacking up the front end and with the help of an enlisted friend, try and spin the front wheels while they hold the brakes? This will tell you if you're building any pressure in the front brakes. Also are you certain that you've adjusted the rears correctly? If they're too far out, you'll be dragging the rears and can potentially cause the rears to lock prematurely before enough pressure is sent to start applying the front brakes.
It was always my understanding that pressure was sent to the fronts first, then residual pressure was sent to the rears from the valve to assist in slowing down, hence the reason that even on my 77 C10, the original shoes were still installed after 48 years. Yeah they needed to be changed only because the left rear wheel cylinder popped and made a mess![]()
so you said you checked everything 5 times, but you verified you replaced things as a parts canon and did not inspect things up closeCaA) No idea. I replaced all the existing stuff with new parts the way the old stuff was assembled. B) The new stuff is stock replacement parts and looked just like the old stuff. I don't take wheel cylinders apart to verify size.
Yes I did that and the fronts wont turn with the pedal pressed. Of course that's just me trying to turn the wheels by hand. The thing is, the rear wheels lock up with just moderate pedal effort, and the fronts don't lock up at all even with max pedal effort. The rears are adjusted to the point where I feel a slight drag when turning the drum. ThanksBefore getting all crazy and reconfiguring things and cutting into stuff, have you tried jacking up the front end and with the help of an enlisted friend, try and spin the front wheels while they hold the brakes? This will tell you if you're building any pressure in the front brakes. Also are you certain that you've adjusted the rears correctly? If they're too far out, you'll be dragging the rears and can potentially cause the rears to lock prematurely before enough pressure is sent to start applying the front brakes.
?i disagree, if everything is checked five times , then it couldnt be the case unless your tires are grossly different in pattern size and stickiness
