Rear Brakes Locking Up
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Also, did you verify the piston size of the replacement master cylinder?
CalSgt
CA
Casey
The computer I'm on wont let me edit a post so here's another...
Please post a picture of your front rotors/calipers from the back side
Please post a picture of the rear assembly with the drums removed
Andronikos
Meriden, CT
There is always some confusion between “Combination” valves and
“Proportioning” valves…
Get a Wilwood valve similar to this one, make sure of the fitting size.
Mount and plumb it into the rear brake line, and adjust it to where the rears don’t lockup.
This is very popular in circle track racing.
I have looked at these and I'm fine with it. I have some questions on the plumbing. Simply add this like you said with no other changes? I can leave the existing plumbing as is?
Andronikos
Meriden, CT
A few clarifying questions:
Did the problem exist before replacing everything?
if not did you verify your new wheel cylinders and calipers had the same diameter pistons as the originals?
A) No idea. I replaced all the existing stuff with new parts the way the old stuff was assembled. B) The new stuff is stock replacement parts and looked just like the old stuff. I don't take wheel cylinders apart to verify size.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Check to see if your rears are dragging during normal driving. Go drive like a mile without much braking and see if the drums are hot.
I fought rear brake drag when I did my brake job. Changed the master and brake pads and shoes, nothing else. Ended up with brake drag. Nothing fixed it but driving it, I still don't think it's 100%. But the drums aren't 400 degrees anymore.
83Stepper
Massachusetts
Chad
Before getting all crazy and reconfiguring things and cutting into stuff, have you tried jacking up the front end and with the help of an enlisted friend, try and spin the front wheels while they hold the brakes? This will tell you if you're building any pressure in the front brakes. Also are you certain that you've adjusted the rears correctly? If they're too far out, you'll be dragging the rears and can potentially cause the rears to lock prematurely before enough pressure is sent to start applying the front brakes.
It was always my understanding that pressure was sent to the fronts first, then residual pressure was sent to the rears from the valve to assist in slowing down, hence the reason that even on my 77 C10, the original shoes were still installed after 48 years. Yeah they needed to be changed only because the left rear wheel cylinder popped and made a mess :(
I have checked them five times. Seriously, five times. Everything is "perfect".
i disagree, if everything is checked five times , then it couldnt be the case unless your tires are grossly different in pattern size and stickiness
brake hose diameters swell in and restrict, uncle tony showed one that had a pin hole diameter to through it
And was like wow, but when they do this they are not sound structurally, any reverse of the pressure in the system might check valve the line to stop the fluid and thus hold pressure
the backs get pressure first, the to overcome springs and begin their self-energiziing design, then the fronts have less distance to move to apply, and once the rears were beginning the fronts are getting the pressure and they begin braking, so it feels balanced
Then the pressure is mostly in the front because it needs more ,but the rear is kept mathematically below a point that a normal situaiton would see them lock, so you have as much braking as possible without a way to modulate the pressure depending on load or conditions like ABS and rear load proportioning do
CaA) No idea. I replaced all the existing stuff with new parts the way the old stuff was assembled. B) The new stuff is stock replacement parts and looked just like the old stuff. I don't take wheel cylinders apart to verify size.
so you said you checked everything 5 times, but you verified you replaced things as a parts canon and did not inspect things up close
So you are lying to us or maybe us and yourself
You needed to replace ALL the parts? To the brake pedal pad, to the drums/discs at the other end, to the booster vacuum filter and hose to the intake you REPLACED EVERY component?
please make a list of them if you did not quite literally do that
words have meaning and every single part of the system has a specific purpose, and some of them I think of would affect things you might not even realize means that you may be missing something
If you have a list on a website like amazon you could send screenshots too
Otherwise actually seeing your brakes like @CalSgt says is my vote on next thing (plus tell us what everything was)
CalSgt
CA
Casey
The first question was asking if the rear brakes were locking up before the work was done, did you not drive it before?
The reason for the second question was “stock replacement” could still be wrong parts, due to different options many incorrect parts can still bolt right on and sometimes even work just fine. If you still have the old parts somewhere don’t turn in your cores or toss them until you get to the bottom of the issue.
Andronikos
Meriden, CT
Yes I did that and the fronts wont turn with the pedal pressed. Of course that's just me trying to turn the wheels by hand. The thing is, the rear wheels lock up with just moderate pedal effort, and the fronts don't lock up at all even with max pedal effort. The rears are adjusted to the point where I feel a slight drag when turning the drum. Thanks
blue10
