SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- Rob
- C20
Ok guys I need a few good ideas.
So like 3 or 4 years ago when I got my 18" open trailer I decided that I wanted a manual way to lock my torque converter in 3rd gear. So the way I have it setup the converter locks in overdrive automatically, but in 3rd I have a switch to control it. I thought this would be temporary and that I'd get the vacuum controller working for the 3rd gear lockup, which I did do, but I discovered I prefer the manual converter lock up control when I'm towing.
So here is what I did. I ran the 3rd gear lock up wires into the cab up the column and to a switch on the shifter.
This is similar to the switch I used:
And this is how it is mounted:
Under the electrical tape is the terminals and zip tie. And I have a thin wire holding the switch to the knob.
It's been like this for a few years and it's function is great and convenient. It's also ugly. Any of you that know me know that I will choose function over looks any day, but I keep thinking that there must be something out there that will do this job better.
So basically I'm looking for a switch or way of mounting a switch to the shifter that might look a little better. Thanks.
