Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
CUCV (84 K30) cab, hydroboost brakes, th400 auto
Talking to the shop who will be rebuilding my th400 and transfer case. They mentioned they had a couple nv4500 manuals they’d rebuild and sell me. I’d like to keep the door open to a future Cummins swap. I know the th400 would die pretty quick behind a Cummins, so spending the time and money on the nv4500 seems logical. Not to mention less parasitic losses and wider gear ratios.
I’ve found a couple pedal assemblies on eBay, but they don’t list them specifically for k30 or hydro boost brakes. I remember reading that the pushrod and spacing is different from vac brake trucks.
Can I run a c/k 10/20 pedal assembly with minor modifications in my truck?
I’m looking to run a hydraulic clutch. I saw this posted earlier, but they’re out of stock. https://americanpowertrain.com/shop...full-size-blazer-clutch-pedal-conversion-kit/
Any other kits like this that are a professional looking setup? Not too concerned with the cost, just want it to be nice. If not, any links to a factory 1985+ setup would be appreciated.
