I ended up getting the wheels. CWO honored my original order price of $633 shipped. Price has gone up significantly $158 -> $225 per wheel. Due to being made in China.
Wheels fit bolt pattern and offset 0 is similar to the stock wheel where you can barely get your finger between the drag link and inner wheel lip.
Issues:
- Need extended length lug nuts to barely reach minimum thread engagement of 7 turns.
- The wheel caps are just a little too small to fit over the front hubs. I can probably dremel out some of the cap so it will clear. I’m fine running without center caps except the wheels have 3 large bolt holes cast into them so it’s obvious you don’t have the cap on.
- Not much depth to the wheel face as they are pictured on the website. Instead of moving the face deeper in the wheel, the hub is deep aka as deep as an acorn lugnut.
