Bed bolt upgrade?
Scruffy49
Law Enforcement Navy
Rosemark TN
Jeff
C10 swb
4.3L
Would “horror of horrors” Ford T-55(?) bed carriage bolts and this style caged nut work on a Squarebody?
I need to pull the bed off my C10 to add a bolt in C notch. Trying to preplan for any factory bolts that end up spinning. The factory hardware is in overall great shape, but the bed floor shows normal farm use pitting.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Just cut/split the nuts for the bed bolts, then remove the factory bolts with no chance of spinning and rounding the square hole.
Clean up and reuse or replace at discretion.
ali_c20
Austria
Alexander
C20, K5
You could spot weld the bolt heads but that makes them non serviceable. Not the best solution but it would work.
If you cut a notch across the head, a helper can use a large screwdriver to stop it from spinning when you remove the nut underneath. Once you get it a few turns loose you can clamp vice grips on the edge of the head and get a better grip. It will be harder to turn as the nut gets farther off, because the end bolt threads are full of dirt and muck.
calredneck
Cailf.
Kerch
Just don't use an impact gun use a breaker bar and a cheater pipe clean exposed threads and lube no striping of holes for me just swapped 2 beds out not one striped hole a rusty 77
duncan_schawalder
