hoagster
Air Force Supporting Member
California
K10, 1500
5.3l
Another state added to my ever-growing list.
Don't go to Washington either. My mom passed and left her car to my sister. I drove it up to her and we went to get it registered and they did the same thing blue book value. I told the clerk are you kidding me you just added some more death tax to my mom, thanks! That is also one of the reasons my truck has been registered and insured this whole time I have been rebuilding it. Don't want to go thru any inspections period.
Sad Sack
Nebraska
Goober
C15
Added.
Supporting Member Army
You don't have to accept that. You can get it appraised as well instead of whatever nonsense bluebook gives out.
Also, if your mother owned it outright and purchased it in California, she likely already paid the sales tax on it when she purchased it in California. According to the Washington DOR, they should not be collecting a use tax on it because the sales tax was already paid on the vehicle in another state and the vehicle was inherited:
https://dor.wa.gov/sites/default/files/2022-03/UseTaxFactsforVehicleTransactions.pdf
Look at Page 2:
Moderator
I guess I'm unlucky. I tape the glass, scrape the glass, scrape the button, clean the glass and button multiple times, even use some 300 or finer grit sandpaper on the button to make sure all residual adhesive is gone and provide some grab for the adhesive, then clean the button some more. After all of that, and waiting to make sure everything is dry, follow the instructions to T.
Numerous times over the years of this failing, I just leave the mirrors in boxes somewhere
Have you always used the sandpaper? That could have something to do with it.
Carb'ed Vortec 350
No, I tried it after I think the third time of the mirror falling off in the Jeep. I thought maybe there was residual adhesive and the sandpaper would remove it and give some extra surface for the new adhesive to grab onto. Of course with a thorough cleaning of the button after a light sanding.
Terlingueno
Fictional Western Sage
Far West Texas
Skeeter
K20 Suburban
350/SM465
A couple days ago I went out to start my Suburban and something didn't look right. There on the seat was my rear view mirror. Apparently the adhesive failed after 26 years as that is when I last had a windshield replaced. This morning I did the prep work to re-attach the metal dingus to the glass since I had to order some JB Weld mirror stuff off Amazon and it will be here tomorrow. Notice in the pic is a hand carved/painted Santo that my ex and I got in New Mexico on the first road trip in the Sub in 1994. It was given to us by an old man in Chimayo NM to keep us safe. Also note the original super worn ignition key that I keep for olde tyme sake...
Since I decided to follow the JB Weld Mirrorweld directions to the absolute 'T' ("For best results, apply in temperatures between 50°-75°F"), and since the overnight low down this way was supposed to be 72-73F, which is at the edge of JB Weld's window of optimum temps, I started the exercise at 0622 hours to give the adhesive about 2 hours to set within the optimum temps. Gonna give it a full 24 hours to cure and then complete the exercise tomorrow morning by re-attaching the mirror to the metal thingamajigger. It is supposed to be 101F later today so we will see whether I have success.
hoagster
California
K10, 1500
5.3l
Look at Page 2:
We'll we got screwed because it was owned out right and they still demanded payment.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
got a code 13 and then a code 44 on the 1990 burb. checked the data from ALDLDroid and BLM/INT are all over the place and the O2 was being really weird. stuck low, then worked back high, then oscillated like normal, then stuck low, etc. O2 volts on a cold engine with key on was right where it should be, so wiring was most likely good and ECM ok. figured O2 is cheap and easy enough to throw a part at it, as it was the likely suspect. disconnected the battery for a bit to clear codes and reset the fuel trim learn to start from scratch vs whatever it was doing with the bad O2 data after I dropped in the new O2 sensor. I took some long drives today and everything back to normal.
Hey Mr. ;) The 87 is gave me a 13 then the 44. Truck surges looking for idle sometimes...just replace the 02 sensor? Pretty much all I can do, yes?
Moderator
Yep, start with the O2 sensor. With the old GM stuff, if you have more than one code, you always start with resolving the lower number code. In this case, the 44 could just be a false code due to the failing 02 sensor and the ecm not quite knowing what's going on.
gmbellew
Kansas city
glen
suburban 1500
yeah, code 13 is prob a bad O2 or maybe a wiring issue....it is an open signal i think. code 44 is lean, prob bc of the bad O2 sensor or connection to the ECM so the fueling is being affected.
Ontheboulder
colville,wa
greg
gmc sierra classic v2500
Getting ready to install a new stereo since the cheapo died. Any ideas on where to mount an Amp in the cab? No room under the dash, maybe on the back wall or on the floor between the seats? It's nothing fancy just trying to get a little better sound.
mxer147
Colorado
Jack
k20
Pasted the new orange headliner to the backer board, still need some paint to match the two tone (brown/orange) bench leather seat cover….not perfect but perfect enough for me. I purchased $30 siphon spray gun from HF to spray landau rubber cement rather than buying 3M headliner paste. Hopefully it all plays nice together since this material is considerably heavier. Orange is a difficult color to purchase this material type, I purchased some lighter material but it never relaxed, creases every 8”. Maybe I will glue some magnetic material to the backside to secure it to the cab roof.
WFO
Texas Panhandle
There's plenty of room under the seat. I've got two under the passenger side, and one under the driver side.
You can run the amp power wire through the drain holes too.
Terlingueno
Far West Texas
Skeeter
K20 Suburban
350/SM465
Ok, mirror assembly placed and secured to the recently affixed metal dingus on the windshield this morning.
Now the durability phase of the exercise has commenced. Since it is supposed to be 102°F today, that should be a good start...
Jeremy89
