Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
Not really put together, I just like to see why my yard is a mess and I can't find any tools and I'm broke.
Today is the day it goes in the chassis though.
Ontheboulder
colville,wa
greg
gmc sierra classic v2500
Success!! new steering gear box is done along with the new stabilizer got the steering wheel straighten out ready for some road miles. Next thing will be new shocks and I think I may still need an alignment Now its time for the best first beer of the day!!
Camar068
Air Force Supporting Member
10 yrs Air Force
did the same over the past few days along with the 1" tie rod upgrade today.
1lejohn
texas
john
k-1500, 2500 HD
Replaced some fuel lines. Was smelling gas when I got out of the truck. Leaking underneath luckily the gas was dripping on the frame and not the exhaust.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
After the truck went in for inspection I knew the breaks would need fixing. I found out a few other things that had to be remedied:
-brakes, as mentioned; new pads fluid flush. Calipers look good to go.
- brake line to front drivers was busted open exposing inner components, replaced.
--front right wheel bearing was loose retightened.
-tag lights out, wiring replaced
- low and high beams crossing, when switched from low to high. Each setting lit one low and one high, but would switch between lghts. Re-wired.
-passenger side motor mount needed to be replaced.
All taken care of with permission from the boss as an early birthday present for me.
I drove the truck to work one day, really enjoying the drive and feeling confident I could trust the truck to get me from A to B. Drove the truck to work a 2nd day just really loving having it back, running right, and brakes not squealing like a stuck pig...
On the way home the truck starts stumbling and slowly dying on me, while on the highway. Wouldn't accelerate above 45, then the check engine light came on. My mind was racing, "This cannot be happening after all the work that I and my local garage just put in to the ignition/tbi components!" pulled over put the caution lights on and immediately scrambled in to troubleshooting. First thing, I reached for the keys in the ignition, but they were in my pocket!!! I pulled them out of ignition after cranking it in the lot at work, after realizing I needed something from the bed before leaving but had to unlock the cover. I forgot to put them back because another co-worker was chatting with me and I got distracted. Yes this is possible in my truck. My first ride, a 88 Safari, did the same thing. You could take the keys out after ignition.
I put the keys back in and restarted the truck. It cranked right back up. I drove home and tested the ALDL(OBD1) with my paper clip jump: code 22.
So i put the previous TPS on that was probably fine, just replaced as I was firing parts after being frustrated. It cranked up and moved around in the driveway. Then started to stumble after cranking to move back. Paper clip test again, this time code 34. So the sun goes down and I start researching "how to clean MAP sensors" , and pulled the previous MAP sensor from the shelf to see how it was looking.
The next day, daughters swim meet, sons baseball game, then a trip to Advance for mass air flow cleaner spray. Popped the hood to take off the map sensor and was intending to spray clean both old and new sensors to try them both hoping a replacement would settle it all. Took off the air filter and the dang MAP electrical plug was halfway in. The fastener had snapped off and was not holding the plug in! "That would do it, dammit" I cursed to myself. Plugged it back in and zip tied it on, for now while I wait on a new MAP electrical attachment to splice in. This cleared the code and the truck is running well again. I had to get to the bottom of it, yet again. It was a super nice spring day here in the Southside of Richmond/central VA, with the temp hovering at 70 and sunny blue skies all day.
Lots of classics and cool rides out cruising today and lots of cool trucks! I managed to snap a pic of one that was pulling in to the same grocery store lot. Posting it in the I Spy A Cool GM Truck thread.
Jrgunn5150
Ionia Mi
J.R.
6.slow
Need to repair the cab mounts on the frame, so this is about as far as I can go with the cab swap this weekend.
Time to start clean up.
gilby959798
CLT NC
GMC K25 Camper Special
Did most of the passenger side rocker, gotta modify it to get the cab corner to fit, so that will be next weekend's project.
1lejohn
texas
john
k-1500, 2500 HD
Finally got around to installing a flywheel inspection cover. It needed a minor haircut to fit. Not bad got it from summit.
legopnuematic
Licensed Junk Dealer
MO
Spencer
10 bolt is done and out of the shop.
Terlingueno
Fictional Western Sage
Far West Texas
Skeeter
K20 Suburban-SM465
Well I am fixin to do some fixin on the Suburban. I have traced my dash/brake light intermittently cutting out to the headlight switch, seems that when the lights go out, if I turn the switch to dim or turn the dome light on, dash/tail lights go back on. The turn signal arm came from Chevy with the 'chrome' plastic coating which is peeling off and looks like absolute crap, so I found some solutions to these issues. Fixin to get after it...
Carb'ed Vortec 350
I would recommend KYB Monomax Shocks
Huffer8
