Wipers randomly turn on.
Gavin.reid
US
gavin
Hopefully this is the right spot, I have looked for any forums about this issue but havent seen any. My 1981 chevy k10 has intermittent window wipers and well driving they go off randomly no pattern or anything just will randomly start going well driving. Anyone have any idea of what is causing this issue and how to fix it? Any help would be appreciated! Thanks
Sent from my SM-G950W using Tapatalk
Gavin.reid
US
gavin
My first thought is a bad intermittent delay module under the dash.
I'll have to check that out completely possible that that's all it is thanks for the info
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
My 81 GMC does the same thing, and the delay function has a mind of its own. I’m getting ready to swap in a later column and wiper motor. That will put the wiper switch on the turn signal lever, and give me a reason to install cruise control
78C10BigTen
pennsylvannia
C10 BIG TEN
My 78 has its own mind too! I have factory cruise though but that dont work because the speedo dont either...
FIRST, go under the dash at the steering column and that's where you'll find the module. Unplug the module at both ends and mate the 2 connectors. Save the module.
If you have any more weird wiper problems then the problem(s) is/are with the motor.
The wiper switches aren't the best and sometimes do go bad but not as often as the module.
At the present, I don't believe anyone has figured out how to troubleshoot the module.
I could be wrong here.
Another thing to check is the wiper motor to ground electrical connection.
78C10BigTen
pennsylvannia
C10 BIG TEN
Im believing mine to be the switch as it wont come on in the delay function but if i just hair touch it they will... but im still trouble shooting the no squirter though.. as for the illusive module i have a spare on hand for back up.
jturner
