will this bulb fit in my guage cluster?
MrMarty51
Eastern Montana
Martin
Heck Yeah man,thems should works fuhr Yuh.
Must rememer,LED stands for "Light Emitting Diode" and being a diode is a one way dam for lectrical current,and so,them LED bulbs`ll work in only one way,What I`m trying to say is,there is a positive and a negative side to an LED bulb,plug it in backwards and it may not, or, should not light up fuhr Yuh.
Green79Scottsdale
G.R. - MI
Bob
Please be advised, they said nothing about being dimmable. Some people don't care about that aspect of it, but I am in the minority in that I want mine dimmable. Hot spots are another possibility with LED's. Not saying it will happen, just a possibility.
To answer your question, yes they will fit. 194 or 168 bulbs are what you need.
T-ROD
Shelbyville, Ky
Travis
They should, other than the neg. & pos. Issue, the dimmer wont work right, the resistance in the switch would be much too low, but they will work as long as fit in a 168 & 194 socket, usually 168 is what you'd go with in the cluster.
:shrug:
attachment.php
1981scottsdale
Edmonton
devin
Scottsdale
Alright thank you all for the help, maybe ill try to find some dim-able, bulbs haha.
Green79Scottsdale
G.R. - MI
Bob
Just wanted you to have good information before you drop good money on stuff that may or may not be what you want. The more informed your choice is the better.
MrMarty51
Eastern Montana
Martin
Good to know about not being able to dim them bulbs,thank You for that bit of info.
1981scottsdale
Edmonton
devin
Scottsdale
Yes thank you for thr info. Ive been following your build thread aswell and youve given me some good ideas for my truck.
alwaysbroken
