- May 18, 2020
- Washington
- Todd
- K20
Getting ready to do the bodywork, truck is about stripped and sanded down.
All the little "dings" are going to get bondo. Got some good quality Evercoat Rage something or other.
BUT, I've decided against cutting out all the bad stuff on the windshield frame, only the worst spot is going to get replaced, as after wire wheeling the snot out of the other bad spots, it's pin holes.
Also have all the visor mount holes to fill on the roof. Aside from the absolute outrageous time it would take to cut out 5 different areas of skin around the windshield, I want to minimize the welding it do on the cab. More disassembly, spot weld drilling, potential to burn ****, etc.
Plan on doing rust converter paint with the little hose nozzle around the inside the windshield frame. And on the outside where the 3 layers are pinch welded together. There's enough holes already to reach it all I'm pretty sure.
The pin hole areas are pretty damn solid directly adjacent to the holes. But I'm considering using lead vs bondo filler. Why? I'm not sure. Seems easy enough, seems "better", I saw it on Youtube?
Question is who's done this before and am I barking up the wrong tree?
Also seems if I eff it up, it should be easy enough to heat up and wipe it out.
Here's what I'm dealing with. I've since cleaned up the areas and its not totally rotten.
