Help with a hirn
yepyep
the moon
joe
v20
350 tbi
Hey all I'm standing out here in the freezing cold trying to figure out what my horns not working it's an 87 square body TBI 350 I powered the horn relay on the orange wire continuity from the green wire out through the fuse box to the horn but no continuity from the horn relay pin to the horn pin on the steering column, I drove my multimeter in there and then pressed down the pin I'm actually going to remove it right now and get bare metal on metal to make sure but I think there's a break or disconnection somewhere on the black wire going from the relay to the steering column horn switch where can I find this?
Thanks
yepyep
the moon
joe
v20
350 tbi
Ok thought i found it but no, there was some loose pins in a connector going up to the steering column fixed those actually have continuity through like blinker right turn signal or whatever up to an allen wrench that i drove in the horn button from the relay. However no matter what I do I cannot get continuity from black wire up to horn button. Is there possibility that I may need to pull the steering wheel? Because I feel like my problem lies somewhere in the steering column
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Put everything back together. Unplug the turn signal switch connector. Find the black wire in the truck side of the turn signal switch connector. Grind that wire. If the horn sounds, the problem is either the turn signal switch itself of missing parts in the coulumn. Either way, it going to take some exploratory surgery to find out what is the problem.
GXPWeasel
Kansas
Greg
1982 | 2015
Sierra C15 | Silverado Z71
5.0 | 5.3
LOL. I read the title, and thought you wanted help with a Hernia. :buttkick:
I can't offer much help with a horn. Mine doesn't work on my '82 because the steering wheel is original, and sucks.
yepyep
the moon
joe
v20
350 tbi
Ya I've narrowed it down to the steering column just got a wheel puller this is pretty lame all for a horn too much damn work luckily I got a parts truck sitting in my driveway
yepyep
the moon
joe
v20
350 tbi
Fixed it it's a bad spring in the steering column not the one for the horn button there's a second one underneath the steering wheel in the selector switch thought I was going to have to change the whole switch out which is a pain but was able to pry the back of it open and put a new spring inside
yepyep
the moon
joe
v20
350 tbi
So ya messed around today fixing lights put a new alternator in, was feeling pretty good about the horn, then i discovered my blinkers don't work now first thought was that large connector with the bladed pins that had some loose ones on steering column and that's part of the problem because if I squeeze it together the right hand blinker works can't get the left hand one to work no matter what The lights just dim when I flick it. Any ideas on this connector with the loose pins? I've taken it apart like 20 times move the pins down put it back together they just push up. And I don't know how the circuit works for the blinkers I assume if the right hand side works the left hand side should or the problem is the selector switch?
yepyep
the moon
joe
v20
350 tbi
So alittle update here got the blinkers working sort of right hand side works,left hand sets the hazards off UNLESS i turn head lights on then it does nothing.....what in the actual **** if anyone has any ideas or has seen this before plz gimmie your 2¢...
Tore column down again can find nothing wrong with switch, loose connectiongs arent loose anymore, changed flashers im at a loss.
duncan_schawalder
