Which dually - 8.1 vs pre-DEF 6.6?
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Man, newer trucks are a pita. I’m half tempted to 12v swap my 1975 f350. It’s a super cab c&c and the rear end/frame look pretty stout to me.
Fastduramax
Uranus
K10 Silverado
This is not even a debate, Dmax period end of any gas motor nonsense for towing... If you're going to tow anything heavier than a moped gassers SUCK anyone who tells you otherwise has never towed with a Dmax, Powerstroke or Cummins... Not to mention the vast tuning options with the Dmax, toss a 120hp non delete tune in it you wont even know that camper is behind you and that's from experience...
The Right side of Washington
If you’re not doing daily work with it, I’m not certain what you could possibly do with a dump trailer that your 3rd gen wouldn’t handle just fine. Don’t even need a dually unless you have a GN trailer and GN pin weights. Which the 3rd gen will still handle over 4k of pin weight easily.
If you are using it regularly and highway speeds/mountains, the 8.1 makes sense to me other than it’s cheaper than a diesel. Otherwise a LLY or LBZ will walk a 8.1 easily with a trailer. And a small tune and it’ll absolutely destroy the 8.1 but not the Allison.
Idk why the 8.1 is even a consideration unless infrequent use.
Moderator
It's a two way street here. Anyone with this opinion has little to no experience with an 8.1L. And I am someone that has DEFINITELY spend A LOT of time towing heavy loads with a Duramax. An 8.1 is not to be compared with a GM 6.0 or a Ford 6.2 or an Dodge whatever they put in those things.
I'm not at all saying that an 8.1 is superior, but it certainly is comparable and can hold a candle to a Duramax.
mxer147
Colorado
Jack
k20
Oh, I forgot to elaborate on the finicky Duramax PCM thing. I have no idea how many times I've been pulling a load down the highway and I've lost all power and had to pull off the side of the road, clear random fault codes, then get back along my way. It's always some stupid pidly little insignificant thing that the tuning isn't happy about, so it goes into some kind of limp mode that is basically undriveable. All the trucks too, not just one or two of them.
I’ve experienced limp mode on my 04, no codes but I am fairly certain it was related to filling the tank to the very top. One time died under significant load, other time it was after restarting.
Moderator
It's always something completely stupid that sets them off. And usually when it goes into limp mode, it sets a few other codes because evidently the pcm is too stupid to figure out why other sensor readings are out of range (due to high throttle % and high speed, I guess) because it's in limp mode. By far, the most annoying part is the low coolant sensor in the expansion tank. If that tank gets a bit low, it will put you in limp mode even if the truck is running cool as a cucumber. It really sucks if that happens when you're near the top of a mountain pass and have to stop, still hanging half way out in the right lane.
Ever since that incident, I bypass the low coolant sensor on every one that I drive.
77Dmax
vt
Joe
The duramax will have better resale value. Folks are all over the older diesels. The 8.1s are beasts, but will always use way more fuel getting the same job done.
legopnuematic
Licensed Junk Dealer
MO
Spencer
I'm guessing it would be a big hassle in California, but in Missouri, you can get a medium duty truck and plate it at 24Klbs which is below the threshold for a CDL (26001gvwr). Depending on your usage can get local plates (within 50 mile radius of the registered address $28/year) or beyond local for $100/yr.
Some potential drawbacks of a medium duty, but also some benefits.
Thats what this guy on another forum did:
4wd, ‘96 FL70 with an 8.3l Cummins and an Allison Automatic
Moderator
But if you put a trailer on it and the GCWR is over 26k, it's still CDL.
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
I was just picking chat gpt (lol) about what swap would be great for my truck (engine and trans wise) and landed on this or the same gen years but diesel.
Great discussion so far.
legopnuematic
MO
Spencer
Good point
Slap one of these bad boys on it and the weight limits disappear (for legal reasons this a joke)
CountKrunk
SW VA
Count
v8 350
Good point
Slap two of these plates on and say goodbye to fees as well!
Moderator
I haven't been down there much at all in the last couple years, but didn't VA get rid of the farm tags that you could just buy at the store? Last I knew, there were new laws that were going into effect that put heavy regulations on what you could use those plates on, and you were going to have to buy them at the DMV to get them.
CountKrunk
SW VA
Count
v8 350
I'm not sure, but there are loads of them around still.
Someone i know got some off amazon and hasn't ran into any issues yet. It's been like 6 months on those plates.
that_orange_c10
