where to route wiring..
R8rPhan
California
Mark
1973 (1979?)
C10 long bed (Frankenstein truck)
Bought some adhesive backed sound mats, and ordered a new MIP floor mat from LMC (comes with 3/8" insulation attached)
I need to run some wires under the floor mat to the back of the cab (security/sound/etc.)..
Should I rout them under the adhesive backed sound mats or between the mats and the new floor mat?
Seems like they would be more stable/protected under the sound mat, but if I ever had to gain access to them, it would be a royal PITA? Or does the adhesive backed sound mats pull up easily?
What is common practice? and why is one way better than the other?
Thanks,
Mark
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I saw once a guy cut channels maybe about 1/4" wide into his thick sound mat and placed the wires in the grooves. Looked pretty awesome actually.
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
I ran my speaker and dome light wires under the door sill plates.
75gmck25
Northern Virginia
Bruce
Factory location for wiring is usually under the door sill plates, although I have seen a few run along the transmission tunnel if there is a console. You do not want to have wiring in an area that will be stepped on unless it has good protection from physical damage.
Bruce
alwaysbroken
